Installing a LT1 Cam
Old Nov 5, 2001 | 06:16 PM
Faithbird88's Avatar
Hello everyone, this is the first time ive done a cam, i have high knowledge of my motor, as well as mechanical knowledge, but im not sure if i have to set valve lash on a roller cam, i believe not, but i just wanna be sure, and is it hard to dial in a cam, and what steps do you take to dail it in, if anyone has some good strong knowledge please let me know, thanks
mike
88 firebird
305 LO3 TBI
Adj fuel regulator
flowmaster exhaust
MSD Ignition w/blaster coil
CF dual friction Clutch
K&N Filter
Performanc fan Swtich
ADS Superchip
Hurst Billet/comp Shifter
KYB/Prothane Shocks/bushings
Soon to be intsalled
Headers (edelbrock or Dynomax)
Hotchkis suspension rear package/Strut tower bar
Old Nov 5, 2001 | 08:13 PM
92fire-audio's Avatar
You are still going to have to set the valve lash... The only way to get the lifters out to get the cam out is to pull the pushrods (or move them), either way, you loosen the rockers and the valve lash setting is gone..
On a side note, how can you tell if the valve lash is wrong? My rockers are kinda noisy until it gets warmed up (not real loud, but I can still hear them with the hood popped..).. I don't know if I ever got the valve lash set right..
How much ya think a shop would charge to set them right? I might just have that done because I don't want to drive too long on valves that are not set right...
Old Nov 5, 2001 | 08:24 PM
ZRATED's Avatar
My rockers make noise when I first turn on the car and then when it warms up they quite down.
One Tight Teal green 91 RS (my first car
All Rustangs suck!!!!
5.0 TBI with Auto trans
Z-28 wheels
K&n with dual snorkel intake
Tx Smog Pump Delete option
Valve cover breather
Rapid Fire plugs with Accel ignition wires,coil,cap and rotor
Flowtech headers with flowmaster and Half way cutout
B&M shift kit with trans cooler and hurst hotshift fulid
Hypertech thermomaster chip
96 LT1 cam with
New liffters and timing chain
All the free TBI mods
Old Nov 6, 2001 | 06:25 PM
about the noisey rocker arms, you might not have the at the correct torque specfication, or your lash could be slightly off, id say a shop, would charge you for about 1 and half hours of work, so depending on the rate you might have to pay about $100....
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
anesthes
Mar 10, 2016 10:35 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
