LT1 cam in L05 TBI Truck (results)
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Finally finished repairing damage done by a bad lifter to my engine. I changed the top end from a flat tappet setup with everything roller from a 94 Z28 LT1. Cam, lifters, spider, pushrods, rocker arms. I changed the valves springs before this disaster.
Results:
1. Its running way too rich for some reason
2. Up to 3000 rpm it feels normal (normally this L05 would start dying off at 3500 rpm and be dead by 4000 rpm stock.
3. Pulled very strong from 3000-5500rpm which is as far as I am going to push it until I get some more tuning done.
So gaining at least 1500rpm of usable power is a big plus for me.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***getting ready for new engine. TBI version of this http://www.airflowresearch.com/Articles/A3-P1.htm
Results:
** Added so far **
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
Found the no 3 and 4 exhaust rockers were too tight causing raw fuel to be pushed into the exhaust and making it appear too rich. Adjusted the valves and it idles as smooth as stock and revs very nicely. Much more top end that it originally had and no notible loss on the bottom.
It may run rich in OPEN loop(closed-loop will be ECU adjusted leaner all by itself) unil you change your PROM. The lowered vacuum signal from the cam forces the RPM/MAP cell into richer ones. Totally normal behavior for a bigger cam... You'll get better throttle response and MORE power and mileage by changing the fuel and spark tables to match your new combo...
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
