I have a TBI short block that i am trying to use parts from. I have one of the heads off and i can't seem to see any kind of obstruction that looks like it could be the infamous swirl port. Does anyone have a pic of this? I was going to use them on my TPI engine but i recently found out about this.
You can't see the swirled port unless you take out one of the intake valves.
I looks like an arial view of a Tornado Slide that you see at the local parks, or even at water parks.
If I knew how to post pics on here then I would post one for you. Sorry
AJ
92 RS w/t-tops 305 TBI Auto.
175K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford Punch 100. 1 - MTX 12" sub
AJ
air cleaner
-B&M TransPak
-Jet Stage2 Chip
how to post pics: https://www.thirdgen.org/messgboard/ubbcode.html
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AJ,
Can you email me the pic if you can't post it?
Thanks Tas. I've been looking for that.
I guess I'll have to bookmark it.
Omega,
I'll take a pic and post it here tomorrow. I'm surprised that Vader hasn't posted one already. He has a pic for everything!!!! He probably even has one of him whiping his own butt.
And no, that's not a hint to post one Vader!!!!!
AJ
[This message has been edited by AJ_92RS (edited November 07, 2001).]
Omega,
AJ
Pic test.
I give up!!!
AJ
HEY!! IT WORKED!!!!!
[This message has been edited by AJ_92RS (edited November 08, 2001).]
I give up!!!
AJ
There ya go Omega.
I finally got my Digital Camera to work with my new PC.
AJ
AJ
Pic no workie
I guess they don't like to host pics. No problem, i just cut and paste.
Is the curved lit up section the swirl casting? It doesn't look like much... that little thing is what makes the 187 heads so bad? Wow.
Thanks for the pic AJ
Well the little lip that you are seeing is closer to you than the rest of the port.
Pretend that you are a bird looking over one of those tornado slides at the park. The slide spins counter clockwise in this pic.
If I had a camera that wasn't so cheap (it was free) then you would be able to see it better.
I don't thing the swirl in the port is what makes these heads bad. It's the small intake runners and weak casting that makes them bad. Well not bad, just not good for performance.
AJ
AJ
Thanks AJ, i appreciate the help.
Would anyone like to buy a set of 91 TBI heads?
Dyno Don
close
Actually I ported a set of 193's(350 swirl ports) and gained 40 hp to the rear wheels.
Not too bad for a no good set of heads!
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC Ex.
14.94-92.00 mph
SPDC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
'92 CAMARO RS
B4C Alt.
Stock TBI manifolds
'85 IROC Ex.
14.94-92.00 mph
