Instructions for Open Element Air Filter?
Old Nov 11, 2001 | 10:02 PM
DAHULK2000's Avatar
What's up guys......just a simple question, Does anyone know where i can get real instructions for installing an open element air filter?......thanx!
Eric
92 Firebird Stock
Old Nov 11, 2001 | 11:31 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
If you go to the tech articles, it will be in there. If that is not good enough, you can always try searching through the past posts. I've learned a lot from these guys/girls. Use it to your advantage.
Old Nov 11, 2001 | 11:32 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
Just the filter? Or the whole cleaner + filter? (Just messing with you).
Somebody made a good web page tutorial with pictures and stuff (search all the message borads and you'll find it somewhere).
It's really not that complicated...
Basic stuff:
(1) pull the old cleaner, hose, breather filter hose, warm air line, valve & tube, etc. out. (2) Drill/punch out a hole (usually already perforated) in your new open element cleaner so that you can remount the IAT sensor. (3) With the IAT sensor in place on the new cleaner, installation of the cleaner itself is pretty obvious - it sits right where the old one was, hold it in with the wingnut.
Clean-up stuff:
(4) Get a push-in breather (and new grommet, if the old one in your valve cover is cracked) to put in place of where the hose that went to your cleaner's breather filter from the psgr. valve cover was. (5) Buy a variety pack of vacuum plugs (from any parts store) and cover the now open outlet on the throttle body.
I don't think I left anything out. If I did, you can leave a really nasty flame here later.
Joel Geerling
Red 91 Formula, 305 TBI
Edelbrock 14x3 open element
TBI 1/2" spacer
Hypertech street chip
Crank/Alt Pulleys
Exhaust is next!
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
wruiz
Aug 13, 2015 09:07 PM
