Anyone ever seen this before?
Old Nov 11, 2001 | 11:11 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
This is what kind of sensor I have in my stock TBI filter. I am suposed to be able to remove it to use with the Open element, but it's pretty much made into the housing. If you know what it is, or have even ever seen it before, let me know.
Here are some pics of it.
http://www.geocities.com/tzfbird/18.html
http://www.geocities.com/tzfbird/17.html
http://www.geocities.com/tzfbird/16.html
[This message has been edited by TZFBird (edited November 12, 2001).]
Old Nov 12, 2001 | 03:52 AM
JPrevost's Avatar
Car: 91 Red Sled
Okay, first off let me start by saying that is one weird website. Not my buisness but if you don't mind me asking....why?
As for that sensor..it's your MAT or IAT Manifold/Intake Air Temp. You can just zip tie it to your MAP sensor which is on the firewall.
As for the other sensor, scrap it, it's your heat riser. Just be sure to plug the vacuum lines!
, Jon (350 TBI!)
91 Red My website
[This message has been edited by JPrevost (edited November 12, 2001).]
Old Nov 12, 2001 | 10:13 AM
firbird's Avatar
"Osama Bin Laden's Homosexual Hideaway"
WTF IS THAT? I think you really need some help and guidance.
[This message has been edited by snflupigus (edited November 14, 2001).]
Old Nov 12, 2001 | 10:32 AM
TZFBird's Avatar
Engine: 327
That's not my site. It's a friend's site. he has the digital camera, so he posted them on his site so I could get to them. Sorry about that. I did not make that, or have anything to do with it. IT IS NOT MINE!!!
I changed the links so that ya don't have to go to that again.
Old Nov 12, 2001 | 10:58 AM
firbird's Avatar
ok... well i did pretty much the same as jprovest, but i did not take it out of my air cleaner i just unpluged it and through it away and got a new sensor because i figure its been there for 9 years and has over 150k miles so i just got a new one and pluged the vacume lines
Old Nov 12, 2001 | 12:01 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
The AIT Sensor, towards the rear or the air cleaner, can be reinstalled in your new open element air cleaner if you want. I cut a hole in the bottom and remounted it there.The heat riser switch is no longer needed(except possibly at smog time)
Also, relocating the IAT sensor to a cooler area (like ahead of the radiator support) will richen up your fuel mixture and possibly give you a little more power.You'll need to make an extension cable to do this.
Tying it to the MAP sensor on the firewall(or anwhere convenient)would also be fine, if you don't care about how it looks.
Just don't leave it somewhere it'll get melted.
-Rich-
Old Nov 12, 2001 | 03:17 PM
TZFBird's Avatar
Engine: 327
I used a resistor instead of the IAT. I had talked to snflupigus since he wrote the tech article on Open Element Installation. He says he has never seen something like it before. I just want to know how to get the piece of crap put of there. I have tried everything but cutting the actual metal around it. it seems to be welded in there. I don't know how to get it out. Should I just go to a salvage yard and get one? I ahte using a resistor that tells the engine it is 70 when it's actualy 20 degrees. For some reason, that doesn't seem right. The engine runs hard enough on ice at startup as it is. What's with the 1500rpm idle anyway? All I can do is spin when I start it up in the winter. I basicly have to use the park brake until it warms up to keep the wheels from spinning.
Does anyone else have a sensor like this one? If so, how do I get it out?
Old Nov 13, 2001 | 08:07 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
now you guys have me wondering...what is the address to teh old site?
-brian
1991 Camaro RS
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
My car's webpage - z28boy.cz28.com
President - Central New York F-Body Association
Email - z28boy@twcny.rr.com
AIM - "Z28 Boy"
Old Nov 13, 2001 | 08:56 AM
NTChrist's Avatar
<font face="Verdana, Arial" size="2">Originally posted by TZFBird:
</font>
That sucks! I had a '84 F-150 with the same problem. On icy roads in western Canada it was great! The rear drums didn't even slow the wheels down, and the rear tires would push me through an intersection while the front ones were locked up. I got used to shifting to Neutral whenever I stopped.
As for the IAT, I'd have to say that if you're not keeping the old housing, cut away, my friend. If you lack exotic tools, just drill a hole or two, and use a pair of tin snips. Personally, I've never seen a sensor like that, but hey. As for the resistor, JPrevost will tell you there are better ways to enrichen the fuel mixture.
No guts, no glory.
Old Nov 14, 2001 | 10:53 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
ya, i told him to post these pics because for like 2 days he tried to explain what it looked like and couldnt, finally i said well you could just use the resistor bandaid. He finally go some pics and showed em to me, and i said. WTF is that? ive never seen an iat that looked like that. could it be aftermarket junk or something somebody added before he bought it? one of those gimic things that works like the resistor trick? or could it be that gm got creative one time and said, hey, we gotta leftover from that prototype junker, put it on this car. well, if nobody has ever seen it, tz, if the plug is different than you see on my article, and you can grab a new iat and plug at your local yard, otherwise just go ****** an iat. little stuff like that, you dont even have to pay for .
