Injectors/Fuel Pressure
Old Nov 14, 2001 | 05:17 PM
Trent257's Avatar
im running on a stock injectors, fuel pressure, how can i up the fuel pressure, and what kind of injectors should i get?
also my fuel filter has never been changed, should i get a new one?
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco cat
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
Old Nov 14, 2001 | 09:36 PM
JPrevost's Avatar
Car: 91 Red Sled
Change your filter. The tech article write up is on the tech articles page, link is off the home page.
Old Nov 15, 2001 | 09:44 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
These filters need to be changed regularly,so do that first.Buy adjustable fuel pressure regulator, or modify factory unit as in tech article on ultimate TBI.A few companies sell them,if you're lazy, like me.
Turbo City's is about $70.
http://www.turbocity.com/TBIPowerMain.htm
-Rich-
Old Nov 15, 2001 | 10:11 AM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
After you change your filter, probably the best investment you can make is an in-line fuel gauge. Your stock pressure should be between 10-12psi, if it's not, check for problems. With your setup, stock injectors are fine, don't make the mistake of getting bigger ones like I did, Jon will agree to that. It'll screw your "choke" cycle all up. You might find a little more power if you get an adjustable pressure regulator, although JET reccomends you keep it under 13.5psi for the street. The JET regulator sells for $65 and is adjustable, but you need to do some drilling in your TBI to make it truly adjustable without having to take the top half of the unit apart to get to the bolt. Do a search for regularors, there was a recent message on the boards that delt with a regulator from GM that was a vaccum advance type thing, that gives you an idle pressure, and a much higher WOT pressure. Good luck- Randy
Old Nov 15, 2001 | 11:36 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
if you plan to really mod your engine someday, then get the vacuum adjustable regulator. if you just plan on boosting your hp a little bit. make your own adjustable. if you have 70$ to throw in the garbage, send me 70$ and ill send you a modified stock regulator, or hey maybe even and vacuum adjustable since they are only 45. Anyway, dont get larger injectors until you are ready for over 260hp. until then your injectors are plenty. even after that, they can work at higher psi's. Your engine should respond well to about a half psi increase with your exhaust mods. and a little bit of chip programming wouldnt hurt after that either. But get a fuel pressure gauge if you are going to be adjusting, it will help you out in the long run.
Old Nov 15, 2001 | 12:12 PM
super chevy's Avatar
Where can I get that vacuum sourced adjustable regulator?
Thanks,
SC
db057
Jan 10, 2020 08:55 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Stryker412
Sep 20, 2015 06:59 PM
TBRays98
Sep 6, 2015 05:05 PM
