TBI injectors and alcohol compatibility
Old May 14, 2007 | 02:57 PM
Deviant7's Avatar
Car: 95 Chevy c1500
Engine: 305 TBI
Transmission: dying 5spd
Axle/Gears: no idea
I know search, I tried.
Is there any consideration I need to account for to run ethanol though a TBI injectors. This will not be a thirdgen, but a tbi converted car.
thank you
Old May 16, 2007 | 08:39 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: TBI injectors and alcohol compatibility
The main issue I can think of is corrosion as alcohol absorbs water. This will effect everything in the fuel system. Check Delphi.com. They have an injector catalog that lists the various TBI injectors and they also state the alcohol compatability there as well. IIRC the TBI injectors are on the second page of the catalog.
Old May 16, 2007 | 10:07 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
What about Pure Denatured Alcohol? I was told to run this before going to my emissions check...to run cleaner as I have no smog setup or header tubes.
Also what about methanol? does Delphi cover these?
Old May 19, 2007 | 09:35 PM
Car: 88 Camaro SC
Engine: SFI'd 350
I think just ethanol was covered.
Old May 22, 2007 | 01:46 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
I ran E85 through my TBI unit for about a year. I stopped after I determined that it did no good. My injectors continued to work fine for a couple more years till I put that car to rest.
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
Keith5
Aug 27, 2015 04:37 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
