JPrevost, Joby, Scanning Software!!!
Old Nov 26, 2001 | 01:04 PM
92Camaro305TBI's Avatar
I went to hook up the cable I made for WINALDL Version 1.02b and the only connection I could find under the passenger dash. There was a connector with A-H on one side and I-O I think on the other, I don't remember all of them, if you want pictures let me know and Ill post them tonight. Anyhow, I disconnected the A-H and plugged the Ground into A and data into E, The program was started and plugged into com1. I turned the key and the car wouldn't start. So I connected the two connectors (with the data and Ground still there) and the car started. I let it run for a little bit and still no reading.
Do I have the right connector?
Does it sound like I made the cable incorrectly?
Let me know if you need more info. I really want to get this to work.
Thank you!!!
92 Camaro 305 TBI Automatic
https://www.thirdgen.org/rides/index...ew&rideid=6100
Old Nov 26, 2001 | 01:35 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
I don't know about the 92 Camaro, but a friend of mine have a 86 IROC. On that the ALDL connector is located under the dash on the driver side near the center of the car.
There should only be a small plastic lid to remove. Nothing should be connected to the ALDL port.
This is what it looks like on my 84 Corvette:
Jonas Bylund
Old Nov 26, 2001 | 02:12 PM
Thanks that would help a lot if it was on the driver side, I'll take a look tonight... Does anyone know where the ALDL is specifically on my car. I guess I was assuming since the computer was there on the passanger side, the ALDL would be there too) Oops
Thanks again.
Old Nov 26, 2001 | 02:35 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
It'll be on your drivers side just to the right of the fuses. You'll see it. I plugged my wires into the same locations as in Joby's picture and it worked great.
Do they make a aldl connector that you could put the wires into, then plug that into the aldl on the car? Just to clean things up a little...
Chuck Kulchar
1991 RS
Open Element w/K&N
3" cat and Force II cat-back
Old Nov 26, 2001 | 02:44 PM
JPrevost's Avatar
Car: 91 Red Sled
Mine is located right next to the fuse panel. I'm moving it because my underdash neon tubes make it difficult to hookup the diacom cable.
There is a part number floating around that is for the Autoxray to GM aldl. This cable can be hacked up if you want.
Jim and Popapork are working on a plug mold in some class they're taking at school. That's all I was told and I'm not sure when they'll have some made. I'll post when I get more information about it.
Old Nov 26, 2001 | 02:46 PM
Thanks guys!!!
Old Nov 27, 2001 | 10:47 AM
Cool, I got it to work. Now I need a really long power cable so I can drive with the computer in my car
Or I just need a laptop
Thanks guys
Old Nov 28, 2001 | 01:57 PM
PopaPork's Avatar
Yes that is true gentlemen step right up I am making a ADDL connector for us cheap A$$es. I got the machine shop and model making shop up at school and since I am a design major I will figure something out. I wil get some prototype pics up on my page or on here soon. I might even try to sell them How much you guys think would be a fair price? Or how much would you all be willing to pay. I aint tryin to make a buck just cover the cost of the material
1989 RS Camaro
305ci TBI
Mods:
Hedman Header
Highflow Cat
3inch catback pipe
FlowMaster 80 Series Muffler
14x3 Open Air Element
8.5 HighTemp Spark Plug Wires
4.7 Ohm Reistor
Torque Converter Lock Up switch
www.rit.edu/~cjp8408
AIM: PopaPork
Old Nov 28, 2001 | 02:09 PM
well since I made my own...
I would be willing to paylets see... $4 for 9pin connector. $2 for 5-7 ft cable. $1 for resistors $4 for workmanship and then shipping.
so.. $11 Plus shipping. Max I would pay is $20 all together
[This message has been edited by 92Camaro305TBI (edited November 28, 2001).]
Old Nov 28, 2001 | 04:06 PM
JPrevost's Avatar
Car: 91 Red Sled
pork, get back to us with the cost of meterials, then add shipping and include only like 6" of wire. It will have to cost less than the AutoXray adaptor. I used that and it was like $30 after the handling and stuff.
, Jon (350 TBI!)
91 Red My website
1992Z28!
Nov 19, 2015 07:33 AM
RGB2015
Sep 20, 2015 09:26 PM
Deemax
Sep 12, 2015 06:53 PM
92firebirdguy
Sep 10, 2015 10:33 PM
86camaroman201
Aug 19, 2015 04:52 PM
