GPH flow #'s for big block fuel pump
Old Nov 27, 2001 | 11:19 AM
rsilver's Avatar
I have searched the archives and found the flow numbers for the small block electric in tank fuel pump which is supposed to flow 29GPH @ 0 PSI. Anyone know what the big block
pump flows and if it will fit in my tank? Thanks for the hlpe.........bob
91 camaro RS convert,GM crate 350 with LT1 cam,edelbrock 6085 heads,9.5:1 comp, edelbrock TBI intake bored to 2", 65# injectors,454 TB, Command perforance custom chip(still tunning) ,dual fan conversion,
ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back,Flowmaster,
T-5, centerforce 2 clutch, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets, edelbrock STB
Old Nov 27, 2001 | 11:25 AM
fast_broker's Avatar
Don't have the numbers you need but I agree that you are getting close to the limit on that pump. I usually run external TPI pumps (for TPI, TBI and carb) after I drop the tank and remove the pump/filter assembly and replace it with a sock/pickup sock. Just easier to screw with in general if something goes wrong later. This way, you are confident of your fuel supply.
Have you run a FP gage while driving to check for fuel stavation at WOT and high rpm?
Old Nov 27, 2001 | 11:16 PM
rsilver's Avatar
I need to look into the external fuel pump thing I guess. That is probably the easiest and most flexible way to go. I have not check FP with a guage, but the pump is old
and I have an intermittent WOT problem which we cannot fix by adding more fuel to the prom.Sometimes the engine pulls strong to 6,500 and sometimes it stops at 5,000 and breaks up.If I back off on the throttle it will still pull to 6,000. Seems I gotta try more flow at the pump so I got to decide which pump to use. I don't know if the big block pump flows enough...........bob
Old Nov 29, 2001 | 04:52 PM
90RS5.0TBI's Avatar
rsilver: what modifications have u made to your TBI or what kinda things have u swapped out. i see that u did all that stuff and where did u get them from how well does it perform
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
