Got another TBI unit, almost ready to bore it out...
Old Nov 28, 2001 | 03:44 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I braved this crappy MO weather (rain/ice) and got another TBI unit from the junkyard. It was nasty so it's outside soaking in ChemDip, which has made me soo loopy it's rediculous.
Anyway, my buddy Dan is gonna take it to school and bore it out with a CNC mill. I found in the archives that 48mm is as big as you can go. That's good since he has an old TPI throttle body we can use the plates out of.
Anything else I should tell him to do while he's got it?
'92 Astro, GM crate 350, Holley Pro-Jection Intake, MSD 6AL, 3.42's, 2.5" exhaust, Flowmaster 40 2 chamber, B&M 2nd stage shift kit, 255 60 R15 tires on AR-727's, Polished & Bored TBI, Custom EPROM in progress
Old Nov 28, 2001 | 04:02 PM
JPrevost's Avatar
Car: 91 Red Sled
Remove the ridge around the edge and maybe radius the lip so it isn't sharp. If you can, have him CNC an injector spacer out of a hard high temp plastic!
If you do that, you might need to modify the back of the TB where the fuel fittings come in. That extra metal can usually just be cut off.
, Jon (350 TBI!)
91 Red My website
Old Nov 28, 2001 | 04:36 PM
Tas's Avatar
Tas
if you do the 48mm are the bores going to have the same centerlines as stock or will be be closer to the middle?
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Nov 28, 2001 | 04:57 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
They will have the same center, but a larger radius. Unless there is a better way you know of.
I made an injector spacer by taking two of the normal FM gaskets and gluing them together with RTV. Together they are 1/4
" tall, and no mods were needed to make the fuel lines work with it.
I'm gonna grind the ridge off (and radius)this one like I have on current unit. Some fancy die grinder work and finishing with a Dremel and Mothers Polishing compund worked great last time.
Old Nov 28, 2001 | 05:04 PM
Tas's Avatar
Tas
does the 454/670 TBI have the same bore centerlines? I thought they went in more so the outside of the bores aren't much wider than the smaller TBI?
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
[This message has been edited by Tas (edited November 28, 2001).]
Old Nov 28, 2001 | 05:28 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
That's a good question. 48mm isn't as big as the 2"(50.8mm) bore anyway. So even if the centerlines are a little off it will still fit. It just has to be off in the right direction so they fit.
But I want it to be close. I'm gonna go take some measurements right now and see if I can come to a conclusion.
Old Nov 28, 2001 | 05:44 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
<font face="Verdana, Arial" size="2">Originally posted by V8Astro Captain:
</font>
Anyway I can buy these plates from GM?
1992 Camaro RS LO3 auto
180º thermostat, 14×3 K&N, !Cat, Flowmaster 80 series, and some audio stuff.
Old Nov 29, 2001 | 12:43 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
if you cant buy the plates for gm, you can get em lots other places im sure.
centerlines are same, im sure of it. 59mm if my memory is correct. if they were different, you all would sure be having some weird troubles using the same injectors pods on bigger throttle boddies
Old Dec 1, 2001 | 09:34 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
I'm not sure. Probably. I'm gonna call the dealer just in case we mangle one trying to put it back on.
Good call on the centerline thing Snf.
[This message has been edited by V8Astro Captain (edited December 01, 2001).]
92camaroJoe
Jul 29, 2023 07:57 PM
evilstuie
Jan 9, 2020 08:29 PM
Cornholio7979
Sep 20, 2018 02:31 AM
92camaroJoe
Aug 13, 2015 06:07 AM
89-S-dime
Aug 12, 2015 11:57 AM
