Need help with '89 firebird, bout to give up on her!
Old Dec 4, 2001 | 01:15 PM
HyBird's Avatar
Ok well let me start from the begining! I have and '89 firebird with an L03(305 TBI) and 700R4. We got the car, and it was running pretty well, although it would heat up to 240-250 when you would drive it due to the fact that the coolant needed changing and there was no airdam. My brother drove it like this for a week or two. Well one day he told me that he couldn't get the car started. So I went down to his high school and checked it out, got it started, but it was running like a piece of crap. Only about half as much power as it should have, and when it idled in park it would surge, like go from 700RPM to like 100, almost die and then come back up to 700rpm. Well we took it home, changed the fuel filter, checked the plug wires, changed the map sensor, EGR valve. That helped a little. Well I noticed that the fuel injectors weren't acting right. They were just pissing fuel, not the good conical shape they should be spraying in. Well at the time my bro could not afford new injectors, so he drove it like this. After a while the car started running even crappier. We found out that after the car was turned off the injectors would continue to leak fuel into the throttle body, and when the car was started it would take forever to get it going, like you would have to clear the excess fuel out of the engine. This unfourtnately led to the oil getting thinned with gas, and eventually oil started coming out of the tailpipe! So yesterday I got a whole throttle body with injectors, and put it on. It started it up after putting it on, and the injectors are fine, but the car still runs like horse****! It surges at idle, you can only give it 1/4 to 1/2 throttle from a standstill or it stalls and doesn't go anywhere. Even when giving it that small amount of throttle it tries to stall, it has no top end power at all. You can kind of hear the car missing too. I really hope someone could help me with this, I have no ****in clue where to go from here, and I am starting to hate the firebird!
'89 Firebird L03, 700R4, 2.73 open rear. Glasspack in place of cat with ?Stock exhaust?
Old Dec 4, 2001 | 02:05 PM
Tas's Avatar
Tas
geeze. You check the plugs? If the gas thinned the oil maybe it got on the plugs and valves.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Dec 4, 2001 | 02:08 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
So you have use of a scan tool. There are so many things it could be. Mine acted like that and the computer was bad. I really can't say its your computer but Check it out. Have you gave a check on the timing?
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Dec 4, 2001 | 02:12 PM
HyBird's Avatar
I figured the plugs wouldn't be the problem since the car acted the same before the gas thinned the oil, but I guess I'll give it a look tommorow. No, don't have a scan tool, just use the ghetto little method with a wire and making a jumper where the scan tool is supposed to plug in, pretty cool auctually! We thought it was the computer from the begining but werent sure, casue it sounds like an expensive part, and we weren't even sure if it was bad or not. And I'm not sure how to check or change the timing, if someone could please explain, I would be very appreciative! Thanks for the quick responses so far!
[This message has been edited by HyBird (edited December 04, 2001).]
Old Dec 4, 2001 | 02:19 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Computers are cheap. About $30 if you look hard at http://www.car-part.com you can find them for that.
I would suspect a dying fuel pump which should show up if your plugs are white with the problem you are describing.
Old Dec 4, 2001 | 06:14 PM
Nitroburn's Avatar
Hybird, do yourself (and your brother) a BIG favor to yourselves and get a Chilton's Repair manual for that car. It'll save you a lot of headaches and show you a lot of "How-To's" like pulling the codes from the computer without having a scanner and listing all the codes. Basically, it covers almost everything from bumper-to-bumper.
Here's a link to the manual on Amazon.com
http://www.amazon.com/exec/obidos/AS...321790-2162265
Mike...
89 T-Top Firebird 305 TBI Project Car (with approval from my wife!)
PATRIOTIC1911
Northern Great Plains and Rocky Mountain
Oct 7, 2022 10:38 PM
jhawkeye
May 25, 2022 06:33 PM
Scamo-2.8
May 20, 2016 07:01 PM
InfinityShade
Aug 22, 2015 08:00 PM
wayshegoes
Aug 17, 2015 12:00 PM
