Which injectors to get?
Old Dec 3, 2001 | 02:23 PM
Stoopalini's Avatar
While tuning my engine, I noticed a strange spray pattern on one of the injectors. I removed it to see why, and found out that the circular screen that slides over the tip is warped.
I figure I might as well replace both injectors, considering they have 140+K miles on them.
All of my mods are in my sig, and I do not want to burn another prom.
So, what would be the best injectors to get? Stock, aftermarket, ones for a 350 TBI, .....??
Any suggestions?
Thanks,
Thomas.
1992 RS Camaro - Red
305-TBI/5 Speed Manual- 3.08 geared rear
1.6 Roller Rockers / Open Air K&N Filter / TBI Spacer / ADS Super Chip & custom burned Off-Road Only chip /
Headers - 3" Cat'Back - Flow Master - Adjustable Coni shocks & struts / 16" factory wheels
Old Dec 3, 2001 | 02:51 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
If you plan on doing more mods like headers and exhaust go ahead and get the 350 injectors. It will run slightly richer but it helped my lean condition at 4000+ rpm and WOT. You would need a custom chip to take FULL advantage of new injectors but stock programming ran ok 4 me.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***getting ready for new engine. TBI version of this http://www.airflowresearch.com/Articles/A3-P1.htm
Old Dec 3, 2001 | 03:11 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
Thomas;
Been there, done that. I replaced my 305 injectors with the truck 350 ones. Didn't notice much, if any, power increase. I do however, find the warm up circuit to be real rough and black soot out the muffler in the cold months. I can't bring my fuel pressure LOW enough to compensate for this. Save yourself the headache and buy the matched TurboCity injectors (they're cheaper then OEM anyway). Once you have them in, install an adjustable FPR and a gauge. You then can bump UP the pressure a pound or two. I hope this advice helps you, as I would do this if I could go back in time. Hey, by the way- how do you like your 1.6 ratio rockers? They are on my xmas list, and I'd like to hear what you noticed. -Randy
Old Dec 3, 2001 | 04:34 PM
Stoopalini's Avatar
I already have headers, and a 3" cat'back exhaust. I have 3 chips also: one stock, and 2 custom. I do not want to make any changes at this time that will require me to burn another chip.
92RS,
Thanks for the info! I will definitely look into the turbocity injectors. They list for $69.95 a piece. Autozone had the stock injectors for the same price.
The 1.6 rockers were already installed when I bought the car. The prev owner upgraded to a '97 SS (the bastard )
He had the rockers done at the same time the headers and cat'back were installed. He said it was a huge improvement after these upgrades; but I don't know how much just the rockers improved the performance ......
Thanks for the suggestions guys,
Thomas.
Old Dec 3, 2001 | 11:15 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
dont buy new injectors. you can get a rebuild kit that has new screens orings and gaskets for your pod. your injectors are probably fine. just boost your pressure a bit.
Old Dec 4, 2001 | 09:28 AM
Stoopalini's Avatar
A rebuild kit? Really? That's great!
Where can I pick one up? Do you think a local store will carry it, or is this one of those dealer/internet only things??
Thanks for the info,
Thomas.
Old Dec 5, 2001 | 09:06 PM
75/92 Birdman's Avatar
Car: 1998 Trans Am, 1992 Firebird
Engine: 402 LS2 stroker, 355 SBC
Transmission: T56 in both
Axle/Gears: 4.10 gear Moser 9", 3.27 9-bolt
Hey is this Stoopalini from ColoradoK5? If so, this is Blaze. Just wanted to say hey.
You can buy a rebuild kit and the screens. I replaced them on the TBI in my 2.8L S-10 Blazer. I paid about $3 for the screens and $30 for the gasket kit. Not a bad price considering you will probably have to buy another gasket when you tear out the old injectors anyway. Good luck with it, bud!
1975 Firebird - Pontiac 350, TH350, 27k original miles, rustbucket, ongoing resto project
1992 Firebird - 305 TBI, 700R4, sport appearance package, t-tops, flaming red, 89k miles, Weiand 360 air cleaner assembly, CAT Power Engine Parts race underdrive pulleys, more to come....
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
