Error code32, 115 BLM
Old Dec 4, 2001 | 08:55 PM
92Camaro305TBI's Avatar
I get an error when driving for little while, when I turn the car off and then back on it goes away. So then I decided to hook up the FREE SCANNING SOFTWARE... I got a code 32 EGR... Also my BLMs are at 115
Should I be concerned? I mean will it screw up my car if I don't get it fixed right away?
thanks
92 Camaro 305 TBI Automatic
https://www.thirdgen.org/rides/index...ew&rideid=6100
Old Dec 4, 2001 | 10:00 PM
JPrevost's Avatar
Car: 91 Red Sled
BLM are pretty low. You must have bumped up the fuel pressure or used 350 injectors.
I don't see any ill effects from an EGR error but it's never a good idea to run around with an error code.
Old Dec 4, 2001 | 10:30 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
what is a BLM? and how would I check mine? Thanks- Randy
Old Dec 5, 2001 | 12:40 PM
So was there a suggestion of what to do? Should I up the full pressure? Anything I can do to get rid of the code 32.
Old Dec 5, 2001 | 03:59 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
<font face="Verdana, Arial" size="2">Originally posted by 92RSFivePointSlow:
What is a BLM? </font>
Read up on the DIY-PROM page. It's full of fun stuff like that.
To make a long story short, the BLM is the Block Learn Multiplier. The ECM "learns" how much fuel to add at certain RPM x Load areas. If the BLM is 115, he is running too rich and the ECM is subtracting fuel from the calculation. A BLM of 128 is right in the middle, and no adjustment is being made.
Old Dec 5, 2001 | 05:50 PM
Old Dec 5, 2001 | 10:40 PM
JPrevost's Avatar
Car: 91 Red Sled
A firm on that BLM run down.
I'm at 120 BLM and I can smell the gas in open loop! Man, I can't wait to get into the swing of things with eprom burning. Finally done with finals I can focus all of tomorrow on my car!
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
BWilcox
Sep 20, 2015 12:19 PM
