Trans/ throttle bracket problem!
Old Dec 6, 2001 | 09:57 PM
Chad91Rs's Avatar
Here is my problem.
I've just installed new heads, cam, and a Vortec Air Gap manifold.
The stock bracket does not fit.
I then get the holley bracket for a aftermarket manifold and it doesn't line up right either.(holley #20-97)
Neither one has the right tension on either cable.(no criuse control by the way)
I'm hoping I'm just overlooking something but I don't think so.
If you guys have no remedy for me I guess my only option is fabricating one.
Any insite is appreciated.
Old Dec 6, 2001 | 10:19 PM
JPrevost's Avatar
Car: 91 Red Sled
Well considering I have a similar setup I'm going to be the first to tell you exactly what you have to do to the stock bracket to make it work. It's easy and takes maybe a half hour if you work slow. Basically you'll be putting it in the same spot facing the same direction. The intake mounting hole needs to be bent 45 more degrees to be on plane with the vortec intake manifold! The bolt you'll use is the last one, closest to the firewall. On the other end you will need to slot the whole so that it wraps around the bolt for the coil. You can do it the other way around and make the coil bolt stock and slot the intake bolt side (that's what I did). The problem might occur that you're not using the holley TB adaptor plate. If that's the case you'll need to do more fabrication. If you haven't installed the holley TB unit yet I recommend grinding off the top piece of the throttle linkage and flipping it to the other side with a simple carb screw in fitting. This ensures that the TV cable doesn't rub against the throttle cable.
Old Dec 7, 2001 | 06:52 PM
Chad91Rs's Avatar
JPrevost,
Thanks for the help.
Can't wait to get the damn thing back on the road.
Old Dec 8, 2001 | 12:48 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
here is a pic of mine...
here it is installed...
oh yeah..and i have vortec heads with the air gap intake..so its the same setup as yours.
mine works perfect. took a little fabrication with a grinder, but came out awesome.
-brian
1991 Camaro RS
GMPP 350 HO crate engine - Holley TB, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
My car's webpage - z28boy.cz28.com
President - Central New York F-Body Association
Email - z28boy@twcny.rr.com
AIM - "Z28 Boy"
[This message has been edited by Z28 Boy (edited December 07, 2001).]
Old Dec 8, 2001 | 02:11 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I have the Holley Pro-Jection manifold and I had to do some serious cutting and welding of the bracket they supplied. It was about 1.5" too long, and 3/4" off to the left.
'92 Astro, GM crate 350, Holley Pro-Jection Intake, MSD 6AL, 3.42's, 2.5" exhaust, Flowmaster 40 2 chamber, B&M 2nd stage shift kit, 255 60 R15 tires on AR-727's, Polished & Bored TBI, Custom EPROM in progress
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
92camaroJoe
Aug 13, 2015 06:07 AM
