Timing on the L03
Old Dec 9, 2001 | 03:49 PM
kingtygr's Avatar
Timing on the L03
I've heard repeatedly that if you fiddle with the timing you can get some good results. I'm going to look at my chilton to see how to do it, but does anybody have any suggestions, like how much advance or retard? My specs are in my sig (not much at the moment) Any help you guys can give a newbie would be great, thanks in advance!
Hondas get all the girls.
Camaro's get all the women.
'89 Camaro RS T-top L03, T5, 3.08 10 bolt stock rear, Edelbrock Pro-Flow filter, more to come as the money flows....
Old Dec 9, 2001 | 06:16 PM
Andy89RS's Avatar
getting the ideal advance is really a matter of trial and error. Mine works best a 4* advance, while others have better results with more or less. Your best bet is to start at the factory specs of 0* advance, then advance it 2* at a time, take a test drive, and when you get pinging or reduced performace back it off 1* at a time to find your ideal setting.
Old Dec 9, 2001 | 06:26 PM
kingtygr's Avatar
actually, when i looked thru my chilton manual it said 6 degrees btdc stock for up to the '89's, then '90's and on it was 0 degrees. should i still do the same method you suggested?
Old Dec 9, 2001 | 06:43 PM
Andy89RS's Avatar
Alot of manuals are wrong on the timing. Most Chevy V8s are set to 6*, but the all of the 305 TBIs are 0*. If you still have it, check the sticker under your hood, it'll tell you 0*.
Old Dec 10, 2001 | 02:45 AM
JimmyS's Avatar
Car: 1989 Firebird Formula
Engine: 305TBI
so what do you do to adjust the timeing?
Old Dec 10, 2001 | 09:10 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
1-get a timing light
2-clean/color the timing marks so you can see them
3-connect the timing light to engine
4-disconnect the ESC bypass
5-loosen the hold bolt under the distributor
6-start the car
7-use the timing light to see your timing, rotate the distributor to adjust.
You can find more detailed steps if you look through the archives
ORIGINAL OWNER
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Partial TBI mods, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Richmond 3:42 gears, Torsen HD Posi
Sights & Sounds:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers. Spectre valve covers and accessories, Z28 grille w/aftermarket lights, MacEwen whiteface gauges
NEXT UP: the rest of the TBI mods & Suspension upgrades
Jake_92RS
Jan 28, 2020 10:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
