Walbro fuel pump/too much FP at idle
Old Dec 9, 2001 | 10:09 PM
rsilver's Avatar
Has anyone had a problem with TOO much fuel pressure at idle with the walbro pump? Can my stock AFPR (it is now adjustable) handle the increased fuel flow at idle? Thanks for help.........bob
91 camaro RS convert,GM crate 350 with LT1 cam,edelbrock 6085 heads,9.5:1 comp, edelbrock TBI intake bored to 2", 65# injectors,454 TB, Command perforance custom chip(still tunning) ,dual fan conversion,
ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back,Flowmaster,
T-5, centerforce 2 clutch, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets, edelbrock STB
Old Dec 10, 2001 | 09:57 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
bob..
sorry man i dont have any advice for you as far as the problem goes.
but, i just have a question concerning the pump...what are the specs? how much was it? where did you get it? i am assuming that i am going to need a higher flow pump pretty soon...
-brian
1991 Camaro RS
GMPP 350 HO crate engine - Holley TB, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
My car's webpage - z28boy.cz28.com
President - Central New York F-Body Association
Email - z28boy@twcny.rr.com
AIM - "Z28 Boy"
Old Dec 10, 2001 | 04:42 PM
JPrevost's Avatar
Car: 91 Red Sled
http://www.autoperformanceengineering.com/
From what I've heard there is no problem using the stock fuel pressure regulator. All the extra fuel just goes back into the tank at a high rate that's all. I just ordered the fuel pump so if I have a problem I'll let you all know. If there is a problem make that one more reason to add to the "why you should burn your own eproms" list .
Old Dec 10, 2001 | 05:31 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
I've got the vacuum adjusted FPR, and it works fine with the Holley 255 LPH TPI pump, which is the same as the Walbro. In fact, when I bought it, it said "Made by Walbro" on it! I coulda saved a few bucks by ordering the Walbro. Oh well. Anyways, your stock regulator should be fine, although I would recommend putting a new diaphragm in the regulator first. They're cheap. Good luck.
91RS convertible 355 TBI 65# inj. custom compcam grind .480/.480, Edelbrock TBI manifold, open element, hedman hedders, Y-pipe, flowmaster single chamber, cop car chip, Accel coil, wires, vacuum controlled FPR. 2.02/1.6 cast iron heads. Engine specially made by Pflugerville machine shop. Forged bottom end, balanced. Coming soon: , Torque converter, DIY PROM, bigger TB.
Old Dec 12, 2001 | 10:41 PM
rsilver's Avatar
JP, I ordered my pump on monday and hope to have it in next week, but I am wondering if it is gonna screw up all that custom prom work I HAD TO PAY for cause I don't burn my own chips. So, definitly add it to the list
as a reason for burning your own. Wish I had just bit the bullet and learned how to do it myself.
Well, maybe the pump will solve the problem and I can be done with this. We shall see.
Thanks for the input everyone.........bob
specialized
Jun 18, 2022 09:26 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
AkDrifted
Aug 17, 2015 07:45 PM
