adjustable knob for fuel pressure reg
Old Dec 12, 2001 | 01:00 AM
JimmyS's Avatar
Car: 1989 Firebird Formula
Engine: 305TBI
adjustable **** for fuel pressure reg
Hey yall that has preformed the fuel pressure reg mod to your cars, did yall go a step beyond just sloting the screw. Could i replace the screw with a longer one so that it would stick out the hole and i could reach behind the TBI and adj by hand with out having to constaintly remove the 8 screws and then stick a screw driver in it?
Old Dec 12, 2001 | 01:50 AM
JPrevost's Avatar
Car: 91 Red Sled
You can replace the screw with a 1/4-28 allen head screw. The allen head screw needs to have a similar point on it like the stock screw so you might need to file and you'll need to drill the spring disc with a 7/32" or #3 drill and tap 1/4-28 UNF threads. This seems to be the best setup for easy adjustments with an allen key. If that's too much then get the holley TB unit and adjust the fuel pressure with the stock allen key screw which faces top side .
Old Dec 12, 2001 | 08:08 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
yeah..the holley is MUCH easier to adjust. it's too bad that there isnt any "conversion" to make the GM pod adjustable without having to take it apart.
-brian
1991 Camaro RS
GMPP 350 HO crate engine w/TBI
Homepage z28boy@twcny.rr.com AIM - "Z28 Boy"
Old Dec 12, 2001 | 04:51 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
The Turbo City Pressure Regulator has a knurled plastic **** on it,....no tools required.
You can order the ***** from machine shop supply houses, like McMaster-Carr or others,
in any size you want, if you want to fab your own.
-Rich-
Old Dec 13, 2001 | 05:43 AM
scauffiel's Avatar
It's still a pain to get to if you have small hands... I just JB Welded a rod off of a scribe to mine, worked fine.
http://www.transamtemple.com/modific...re_regulat.htm
Steve
Steve's Trans Am Temple
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
Kaweh
Aug 9, 2015 02:54 PM
