454 TBI/ injector ?
Car: 1991 Firebird
Engine: 383 stroker
454 TBI/ injector ?
Ok boys, I'm finally doing it. I'm pulling the 350 out of my boat this weekend and going to put it into my 91 bird this weekend. I wanna make sure that it is adequetly feed. I have a Perfomer RPM on it now which sits upon a set of Vortec heads and wanna put a 454 TBI on. I need to know what year applications I can use when I try to track on down. And I'll probably end up getting the whole unit, injectors and all cause that's how the junk yards around here sell them. So will I be able to use the 454 injectors or will i have to find 350 injectors? Thanks for the help.
91 Forest Green Firebird with TBI 305 3" Edelbrock Cat back, Dynomax headers, matched flow fuel injectors, injetor spacer, throttle body spacer, MSD Blaster coil, 8.5 mm MSD wires, 160 degree stat, Hypertech Thermomaster chip and low temp fan swich
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
We need a little more info. about your 350 (heads, cam, etc.) you probably won't need a 454 TB or injectors. The stock TBI unit can be made to flow just fine on a 350 with some tweaking. Depending on your set up, you will need 55# or 65# injectors. An adjustable FPR is imperative, especially if you don't plan on burning your own chips.
91RS convertible 355 TBI 65# inj. custom compcam grind .480/.480, Edelbrock TBI manifold, open element, hedman hedders, Y-pipe, flowmaster single chamber, cop car chip, Accel coil, wires, vacuum controlled FPR. 2.02/1.6 cast iron heads. Engine specially made by Pflugerville machine shop. Forged bottom end, balanced. Coming soon: , Torque converter, DIY PROM, bigger TB.
Car: 1991 Firebird
Engine: 383 stroker
well like I said, the heads are Vortecs witch means 1.94/1.60 valves. The cam will be around 262-268 degress with about .460-.480 lift(haven't picked out an exact one yet. But I seriously doubt that I stock TBI even with mods will be able to keep up with a 350's needs, especially with that cam. So I just need years of applications for a 454 TBI.
thejimsterz28
Sep 15, 2015 04:37 PM
