won't idle
Old Jun 25, 2007 | 05:27 PM
NANCY92's Avatar
won't idle
I just changed the EGR valve but no help..305 TBI 1992..very rough idle..hard to start..when starts idles ok for 20-30 seconds or so then almost stalls..sometimes stalls.any ideas?
Old Jun 26, 2007 | 12:28 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: won't idle
Assuming the EGR and associated vacuum circuit are OK, it could be a faulty fuel pump causing the engine to run lean. How does it perform under load? Does it knock or break up/backfire out the TBI? The CTS will also cause similar symptoms if is mis-reporting the temp. Same thing if the MAP sensor is bad. There are alot of other things, but these are the most obvious.
Old Jun 27, 2007 | 02:13 PM
NANCY92's Avatar
Re: won't idle
Checked the MAP sensor..seems to be OK..does not backfire out the TBI..has this problem as soon as it starts cold..Replaced fuel filter and checked pressure ..OK..Could the timing jump..if it did would it have this problem?
Old Jun 28, 2007 | 09:07 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Re: won't idle
How does it run warm?
Old Jun 30, 2007 | 03:38 PM
NANCY92's Avatar
Re: won't idle
Can not tell..will not stay running long enough to tell..when it is running (barely running)and you hit the gas it stumples and coughs real bad out the exhaust!
Old Jun 30, 2007 | 09:37 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Re: won't idle
Does it blow smoke? If not, it sounds like the engine is leaning out. A faulty CTS, bad fuel pump, or restriction in the fuel system would be some likely places to look. It could also be a possible ignition issue as well. Has it had a tuneup recently?
Old Jun 30, 2007 | 11:24 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Re: won't idle
Mine did this. check to make sure egr valve isn't open. mine was related to a faulty egr solenoid allowing vacumn to the egr valve all the time.
Old Jul 2, 2007 | 02:22 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Re: won't idle
A faulty O2 can also cause symptoms like this as well. It usually takes around 30 secs to around 3 minutes for closed loop. Once that happens, the engine will run lean if the sensor is bad and overreporting. Happens every now and then.
Old Jul 5, 2007 | 03:08 AM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
Re: won't idle
mine was doing the same thing i ended up replaceing the idle air control and coolent temp apperently the iacs just wear out over time and the coolent temp sensor was sending differant signals but looking at the gauge you would never known it was bad it was telling the gauge the correct temp but telling the ecm it was 50* hotter
Old Jul 14, 2007 | 09:35 AM
NANCY92's Avatar
Re: won't idle
At last..found the problem!!..faulty fuel pump..had to drop the tank..major job..labor intense..running fine again..thanks for all your input.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
