TBI to carb ecm question
Old Jun 26, 2007 | 07:09 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
I ahve read alot oabout the down sides of not using a VSS ( vehicle speed Senser) and have sopme questions. I am swaping out my motor and am not planning on running that senser on my new motor. I am heard about the car not shifting right and codes being thrown out. is there any way to get around this or tune it out of the computer? i do plan on running a modified 700r4 I know about the toggle switch idea but i don't want to use the senser at all.
Old Jun 26, 2007 | 09:11 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: TBI to carb ecm question
What is going to change that you can't use the VSS?? Your 91 should have an electronic speedo that also needs the electronic speed sensor that is in the tailshaft. If you are swapping to an older 700 your sensor will swap right over.
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
redmaroz
Aug 16, 2015 11:40 PM
