92 camaro rs halfway through a 305 to 350 swap
Old Jun 27, 2007 | 07:34 PM
adrianhix's Avatar
O.k. so I bought a 92 Camaro RS real cheap. This is what I know about it. The original engine (which is in the back seat) was swapped with a 350 tbi. I know the 350 is from a van. It's obvious whoever did this knew what they were doing but did not have time to finish. The drive train is hooked up. Also in the back seat were two starters and two radiators and an extra ECM. This ECM has completely different hookups then the one installed in the camaro so I assume this must be the vans ECM. I tried doing a google search with the numbers on the ECM with no luck.
With this ECM is there a way to determine what engine I have installed?
My next question is, there are wires and hoses still unconnected all over to the engine. Is there some kind of schematic I could look at to determine what is what and where it goes?
I've never owned a car that was water cooled before let alone had a chip in it. I've been reading over this site for the last couple of weeks and it has been an enormous help! I wouldn't understand what I do without it.
Thankyou in Advance
Old Jun 28, 2007 | 09:49 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: 92 camaro rs halfway through a 305 to 350 swap
Dude
Post pictures, ECM part numbers, and all other details that you are not sure of. Otherwise, I doubt that you will get any responses.
SD TBI system is not that complex, but depending on the year of the van there will be differences, etc.
//RF
Old Jun 28, 2007 | 10:05 AM
Ronny's Avatar
Your car had a 1228746 ECM from factory.
Frozer!!!
Jan 19, 2024 04:55 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
