Header Installation
Old Jul 6, 2007 | 11:59 AM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Header Installation
Holy **** putting headers on is a bitch. It took us 3 hours just to get the exhaust manifolds off and all the other bullshit that surrounds it.. But my question is that do i need the small metal lines that go into the old exhaust manifolds?? pic included
Old Jul 6, 2007 | 02:17 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Header Installation
It is better and simpler to keep the air sistem functional. It is also required in most of the world for passing inspections.
Old Jul 6, 2007 | 02:23 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
There is most likely nothing you can do with those lines that attach to the old manifolds. Your new headers either came with their own AIR lines, or they didn't. If they did, connect them up to the existing system just as the old lines were. If they didn't, you obviously don't have underhood inspections and might as well just delete that part of the system.
Old Jul 6, 2007 | 02:51 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
I noticed with my hooker LT's my plugs were a lot easier to change.
Old Jul 6, 2007 | 08:31 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Yea i bought Hooker Headers and the matching 3" y-pipe. Its going to be pretty loud since its bypassing the cat. Ill have a video clip when im finished
Old Jul 9, 2007 | 01:41 AM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Finally got the car up and running but now my problem is that the car is missing. It stalls and flutters with the rpms when you mash it to the floor. I changed the plugs and custom fitted all of them and im guessing its not receiving a good connection? Does it sound like a cylinder not firing or could it be not getting enough backpressure?? etc... My smog pump is disconnected but other than that everything is back up the way it should be.. the only error code going off is the oxygen sensor but its reading fine when i hook it up to the laptop..
Any ideas?
Old Jul 9, 2007 | 08:13 PM
SMKNTRS's Avatar
i feel your pain, i just did mine last weekend by myself and was sore for 3 days lol
Any ideas?
You check all your vacum lines?
Old Jul 10, 2007 | 12:20 AM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
I'm not sure which ones would be messed up? Its weird because when the car first warms up it runs all 8 cylinders fine but when it warms up it stutters and and doesnt want to hardly move. We discovered we had some cracked spark plugs but we fixed them and it seemed to fix the problem until we kept on driving.. My guess is that we bumped the distributer and its running really advanced but its late and I can't check.. And its not arching
Thanks for any help
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
