lots of new stuff, problems!
Old Jul 8, 2007 | 12:07 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
the car has new distributor,coil ,fuel pump and relay .oil pressure switch plugs ,wires ,still doesn't want to stay running .this morning it fired right up! i went out tonight to put it back in garage it stalled as fast as it fired up ,and the last time i believe i heard a backfire coming from exhaust.
Old Jul 8, 2007 | 12:16 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: lots of new stuff, problems!
What happens when you go to restart it? Does it start immediatly without issue? Flood, and then start ok? Flooding is a common isue with some of these cars due to the crude handling of the fueling when cranking. Also, how does it run otherwise?
Old Jul 8, 2007 | 05:31 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
yea i think it floods itself ,like it doesn't get fire all the time. cuz, i get good fuel pressure. then other times it fires right up and runs liike a striped a** ape. also the new plugs are turning black wzy too fast
Street Lethal
Apr 30, 2019 12:14 PM
MantyZ28
Jan 18, 2016 08:30 AM
nuggie
Aug 25, 2015 01:27 PM
Fronzizzle
Aug 17, 2015 02:52 PM
