only 1 injector firing.
Old Jul 15, 2007 | 06:11 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
what would make only 1 injector fire? is it just that its bad or is there something else i should be looking at?
Old Jul 16, 2007 | 04:55 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: only 1 injector firing.
Swap your injector plugs over first and make sure the same injector still isn't firing. If they change and the other one quits you have a short in the wires, otherwise you've got a bad injector or a clog either way time to replace or rebuild that injector.
Old Jul 16, 2007 | 05:29 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
thanks man, i'll go out and do that,and post response.
Old Jul 16, 2007 | 06:45 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i don't know i just decided to put new tbi on it ,and put a new pump in it.when i took tbi off there should of been a lot of gas- bone dry.
Old Jul 16, 2007 | 12:02 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The most likely culprit would be a bad switched ground path or lack of constant +12 volts. The other possible cause would be a dead driver in the ECM. If the injector tests out ok, then youd need to use a DVM to measure teh continuity of the circuit that feeds teh dead injector.
Old Jul 16, 2007 | 04:11 PM
FreeLoader's Avatar
Car: 1997 Camaro z28
Engine: 350 LT1 built to LT4
Transmission: a
Axle/Gears: 3.23 posi
I wouldn't go out and buy a junked tbi when yours may have a fairly simple problem that may very well not be related to the tbi itself...it's just...extra work.
and you don't know what you're buying, wheras you know how old/clean/dirty/whatever your original is.
besides, you really could just replace the injector pod as opposed to the whole tbi, but I really wouldn't do that either.
take the 10 minutes to check the other things first, then go from there.
Old Jul 17, 2007 | 01:25 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
well, it was the pump if not ,definetly the strainer it looked like it'd been at the bottom of a pond for a long time. since it was aprt i just replaced both and the filter .man ,can you see the difference at the injectors. well thanks E-1.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
