Problem, head gasket?
Old Aug 1, 2007 | 01:54 PM
mieta's Avatar
Car: Camaro 1990
Engine: 3.1 v6
Car runs fine for a while, then the service engine soon light comes on throwing 13 code (lean). After that there is bubbling in the cooling liquid container and then the car dies. There is no oil in cooling liquid or via versa, but what else could it be? Thanks for advance.
Old Aug 1, 2007 | 03:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Problem, head gasket?
Bad radiator cap? What's the coolant temperature when it dies? Any white smoke out the tailpipe?
Old Aug 1, 2007 | 11:26 PM
mieta's Avatar
Car: Camaro 1990
Engine: 3.1 v6
No white smoke, temperature is ~220F. How could bad radiator cap stall the car?
Old Aug 1, 2007 | 11:46 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Well it could be a small head gasket leak. Your engine could be pressurizing the cooling system if any cylinder pressure is getting past the ring.
I would compression test all cylinders to eliminate that possibility.
Old Aug 1, 2007 | 11:56 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
I had the same bubling in the overflow. It was the head gasket. I actually pulled the thermostate to see if that was it. Still bubbled.
Old Aug 2, 2007 | 10:30 PM
golden's Avatar
Car: '89 Firebird
Engine: 305 TBI (LO3)
Axle/Gears: 10 bolts 2.73
Like RITTER said , check your compression ...
Old Aug 4, 2007 | 04:33 PM
mieta's Avatar
Car: Camaro 1990
Engine: 3.1 v6
Ok, will check for compression to be sure.
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
