my 92 dumps waaayyyyy to much fuel into the throttle body
Old Aug 22, 2007 | 12:09 PM
third gen crazy's Avatar
i have a 92 rs with a stock 305 and you can see it dumping fuel in to the throttle body i dont know what it could possibly be except maybe a sensor help please I've tried so many things any answers, possibilitys, has anyone else had this problem?
Old Aug 22, 2007 | 01:24 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Re: my 92 dumps waaayyyyy to much fuel into the throttle body
check your vaccum lines and your map sensor. My s10 had a vacuum line break apart at the map sensor. The truck wouldnt run unless you kept the gas pegged! It would blow tons of black smoke out and runs like crap. Hope that helps
Old Aug 22, 2007 | 10:32 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
coolant temp sensor on the front of the manifold caused my bores to FILL with fuel before it could drain past the butterflies when it wasnt workin.
Old Aug 23, 2007 | 02:18 AM
thank you guys i will check both of those out, thank you so much
Old Aug 25, 2007 | 05:49 PM
the coolant temperature sensor didnt work...i dont know what it is im about to give up
Last edited by third gen crazy; Aug 25, 2007 at 05:49 PM. Reason: Automerged Doublepost
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
justin57
Aug 20, 2015 07:05 PM
mdtoren
Aug 16, 2015 05:45 PM
