vacuum adjustable fuel pressure reg
Old Sep 6, 2007 | 12:08 AM
xrcrx's Avatar
Car: C4
Engine: 383 Crossfire
Axle/Gears: D36 3.75
Is it absolutely necessary to have a vafpr to make an engine idle at 23 or so psi, or can I simply run 2-65lb injectors at 23 all the time. I'm getting my fueling system sorted before I start tuning w/the Flash EBL .
Old Sep 6, 2007 | 07:56 AM
88L035speed's Avatar
Car: 1988 Camaro Coupe
Engine: 305 5.0 L03 TBI
Transmission: T5 - 5 speed
Axle/Gears: open diff. & stock 3.08 gears
Re: vacuum adjustable fuel pressure reg
if you read about TBI mods it tells you how to make your stock fuel pressure regulator into one you can adjust yourself, i did it and works great. all you need is a di grinder.
Old Sep 6, 2007 | 09:44 AM
chevyz71man's Avatar
I run 33 PSI through 55pph injectors right now at idle and have no issue. I am sure the idle could be cleaned up a little if I were to run on though.
Old Sep 6, 2007 | 01:13 PM
xrcrx's Avatar
Car: C4
Thanks for your answers!
Old Sep 6, 2007 | 03:04 PM
Ronny's Avatar
you are doing what I did. run higher FP in lieu of utiliizing a VAFPR which i have on my Aeromotive reg but never used. watch your DC at idle to see if it bottoms out. mine did. also at idle i would flip from synch to asynch to reduce fueling which caused a surge and enleanment as fuel was being cutoff(asynch). so i ended up running synch only at idle. but with a 383 you may not have these issues??
Old Sep 6, 2007 | 04:46 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
get the holley apr it's by far the best. You don't need a vacuum one. Not yet that is!
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
mdtoren
Aug 23, 2015 12:52 PM
86IROC112
Aug 17, 2015 02:00 PM
