Is thomas1976 "kickass cold air intake scoop" really useful, and worth $200????
Old Oct 17, 2007 | 09:29 PM
cliffhanger2486's Avatar
Car: 88' Firebird
Engine: 5.0 TBI
Does this intake scoop actually work????
Is this intake really useful, and worth $200? It was posted by thomas1976 under "kickass cold air intake scoop".
http://www.cardomain.com/ride/2668586
Old Oct 18, 2007 | 11:44 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: Is thomas1976 "kickass cold air intake scoop" really useful, and worth $200????
im not positive but i wouldnt see much of a gain through that because firebirds get about no air in there. its not like itll create a ram air effect because it wont where its positioned.
Old Oct 19, 2007 | 06:35 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Since you are guessing, if the stock lo3 air intake set up is good for 170hp what hp range is my set up able to feed?
The scoop is cool even without boring holes int the vented hood. That means there is air flow.
With holes in the vented hood, the scoop + the first part of tubing gets easely cold. What do you call that kind of air flow? I actually got a significant fuel economy from this last modification.
My set up is basicly a flat base open element that doesent suck underhood air, basicly because with the open element I could feel a loss of power wen the engine was hot to the point the radiator keeps turning nonstop.
Here some links to what streats we drive, you will have to be stomping the gas pedal all the time just to normally drive home.
http://www.lambdarallyeteam.ch/phpwe...hp?/category/3
http://genesis.romandie.com/category/2112/12365
http://www.swissrally.ch/articles/20...tion_RIV07.pdf
http://www.shopauto.ch/modules/photo...album=7&page=1
Old Oct 19, 2007 | 11:13 AM
Engine: LO3
ok sorry but i was just taking a shot as seeing how my cars hood basically mates with the front bumper so i dont see much air getting in but i guess i could be wrong.
Old Oct 19, 2007 | 01:10 PM
thomas1976's Avatar
Car: 91 Trans am
Dont clean the underhod, give a look at the black dirty spots that form over years and you will find out were the air comes from.
If I dident have a hood with the grilles, I would have bored some holes trough the sheet metal between the radiator and the front bumper and have the air blow up from below like the tpi camaros.
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
