Does this intake scoop work???
Old Oct 18, 2007 | 08:49 AM
cliffhanger2486's Avatar
Car: 88' Firebird
Engine: 5.0 TBI
Is this intake really useful, and worth $200? It was posted by thomas1976 under "kickass cold air intake scoop".
http://www.cardomain.com/ride/2668586
Old Oct 18, 2007 | 12:40 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Does this intake scoop work???
with a near stock car and stock ECM, I wouldnt use a CAI. The ECM has very little capability to compensate for the cold air, which will skew the fueling, and possibly make the car run poorly.
Old Oct 18, 2007 | 07:17 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
At what low air themperatures will the ECM screw the fueling? Do I have to find a alternative for the winther season?
Since I bored the holes in the hood and put the sealing rubber on top of the scoop, by stomping the gas many thimes on swiss higway, Im making 9.2L/100km (26mls/USgallon) vs the 10.16L/100km before the boring.
Old Oct 18, 2007 | 08:42 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
How about my setup
https://www.thirdgen.org/forums/atta...n-100_2289.jpg
Old Oct 19, 2007 | 07:51 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Theres no real set temperature, but in the cold months, putting a cone element on it so it takes in air from the engine comp. wouldn't be a bad idea. With a stock intake manifold its not quite as bad as theyre fully heated and the coolant will help keep the fuel from going out of suspension. Youll still see some skewing of the AFRs, though when its really cold out as the ECM wont really compensate for the denser air.
Old Oct 19, 2007 | 11:08 AM
thomas1976's Avatar
Car: 91 Trans am
The "fully heated" I understand, what do you intend with "and the coolant will help..." ?
Old Oct 19, 2007 | 01:17 PM
thomas1976's Avatar
Car: 91 Trans am
Sorry I got it - the hot coolant -
But could you explain me "the skewing of the AFRs" ?
Jake_92RS
Jan 28, 2020 10:37 PM
masonta
Aug 31, 2015 10:14 PM
kyle5647
Aug 15, 2015 11:56 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
