coolant temp sensor
Old Oct 18, 2007 | 03:41 PM
bakerstreet's Avatar
coolant temp sensor
what symptoms would a bad coolant temp sensor cause on a 92 rs 305 tbi?
Old Oct 18, 2007 | 03:54 PM
Ronny's Avatar
Re: coolant temp sensor
I believe it tells the ECU coolant is very cool. Car runs super rich.
Old Dec 31, 2007 | 11:32 AM
LoganTA's Avatar
Car: 87 Silver Formula
I think thsi sensor is what causing our 88 formula to run rich after you drive it and restart it once it is warm.The car cannot tell the coolant is warm and is feeding extra gas into the mix thinking the car is a cold start situation.
Old Dec 31, 2007 | 06:21 PM
cdacda13's Avatar
Car: 1992 Camaro
Engine: 5.0L TBI
It can also make the engine take longer to turn over. On my car, the CTS was reading that the engine was hot, yet it was sitting outside in 30* temperature for 8 hours.
Old Jan 9, 2008 | 09:53 PM
Brandon2350's Avatar
Car: 1993 Z-71 pickup
Engine: Heavily modified 355 on TBI
Transmission: Had a 4L60e. Now a 700R4
Axle/Gears: Bone Stock
It will run super rich. A failing cts will sometimes appear intermittent. One minute it will run fine the next it will stumble, hesitate and possibly blow black smoke. I've watched a failing CTS while datalogging and you can watch the commanded AFR jump all over the place and idle is erratic.
If the CTS has failed you could have a completely warmed motor and the CTS wont register it, which it tells the ecm it's running cold so it adds more fuel when in fact it doesn't need it. Often there are 2 sensors. One for the ECM and one for the temp guage.
Old Jan 10, 2008 | 01:57 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
My car wouldn't even start with a bad CTS. It stumbled and died after 10 seconds while driving when it died and when I tried to restart it the throttle bores instantly filled up with fuel and overflow fuel over off the TBI unit.
Old Apr 12, 2008 | 06:15 PM
cameron7710's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
hi i had some ???s i think my coolant temp sensor is bad because my car has been running really rich and my temp gauge hasent been working and i was just wondering if all this would happen without eny dash lights going on?
Old Apr 12, 2008 | 06:53 PM
F_N_JUNK's Avatar
Car: 1991 Camaro
Engine: Morris 434 Single Turbo
Transmission: TH350
Axle/Gears: 9" Ford w/4.11's
Funny this got posted up cause I just was changing the thermostat in my car and i barely tapped the coolant sensor and the whole-connector came off !! My car had been missing and I changed the plugs 4 times. Put the new sensor on and it runs great now!!!
I was changing the thermostat cause the intake had a slight leak and it looked like it was comming from the thero housing, actually turned out to be leaking thru the top of the sensor!!
Old Jun 3, 2008 | 10:24 PM
Shred's Avatar
Car: 1986 Iroc-Z
Engine: 350cid crate
Transmission: t5- 5speed
Axle/Gears: stock
whats the sender part number for a carburated v8?
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
