another IAT question, HELP.
Old Oct 21, 2007 | 10:26 PM
cliffhanger2486's Avatar
Car: 88' Firebird
Engine: 5.0 TBI
IAT sensor is that little thing that attaches in the air cleaner am I right? it has a little black square around it and like a little white plastic basket on the end? Anyway, I melted the top part, and the SES light was on for a minute, but then off when I moved it to a diferent spot. I am not sure if its destroyed or not though. Can I put it in the snorkel of my cold air intake by the air cleaner? Will my car blow up if I don't replace it, or just run poorly? Where is the best place to put it.
Old Oct 21, 2007 | 10:41 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: another IAT question, HELP.
Id just put it in the CAI. You can even use a threaded coolant temp sensor. The actual RTD element is the same for all GM temp sensors. The car wont blow up without the IAT per se, but the IAT does effect the fueling and knock sensor handling. The code was probably from the IAT getting too hot when it melted.
Old Oct 21, 2007 | 10:44 PM
Car: 88' Firebird
Engine: 5.0 TBI
alright thanks. I'll get a new one I guess.
PATRIOTIC1911
Sep 1, 2015 07:26 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
Djmathis123
Wheels and Tires
Aug 23, 2015 11:34 AM
redmaroz
Aug 16, 2015 11:40 PM
