Please Help
Old Oct 24, 2007 | 08:09 PM
mr. maro's Avatar
Please Help
Just put on some iroc rims on my RS. Stock 16 inch, once I put them all on and torqued the lugnuts to 100 I got in to drive it and the car wont move just idling. When I gas it, theres a loud grinding noise like something is rubbing together. I checked around all the tires and the tires are rubbing against anything. So Im thinking its something on the inner part of the wheel maybe. Any ideas on what I should check?
Old Oct 24, 2007 | 08:15 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: Please Help
aaackkk!!!!! Stop!!!!!!!
All 16" camaro wheels have different offsets for the front and rear wheels. Go check, they are labeled between the spokes. Hopefully you haven't ruined the wheels yet.
Old Oct 24, 2007 | 08:28 PM
mr. maro's Avatar
Re: Please Help
Sh*t!!! The fatter tires were on the front rims and the skinnier ones on the rear rims. I asked the auto parts guy where i got some of the tools and he said it should all fit. Damn it. I just backed out of driveway and drove about 20 feet. Hopefully they are still ok.
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: Please Help
run your hand all around the tire front and back. make sure the tire is not rubbing anywhere. most likely the tire sits in too close to a plastic trim piece or something. find where it is and give us a report! also 100 ft lbs of tq is not right. alumn should be 85 and steel 125 according to my manual. good luck!
yep that's why in small print on the inside of the rim it says "FRONT" or "BACK". gives me an excuse not to rotate them. lol!
Old Oct 25, 2007 | 01:52 AM
mr. maro's Avatar
Re: Please Help
it seems as if the tie rod end in the front is hittin the inner part of the wheel. Im going to try to find a spacer or just get some washers in between there and check again. and i will re torque them to 85 too.
Old Oct 25, 2007 | 01:39 PM
mr. maro's Avatar
Re: Please Help
Will spacers/washers do the job?
Old Oct 25, 2007 | 02:35 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: Please Help
Why dont you just rotate the front's to the back and vice versa and it should all work out (unless you put them on random, and have only one rear on the front).
Either way, you should probably replace the whole steering assy maybe more. If they were hitting hard enough to hold up the car when it was idling in drive, that is alot of force.
Old Oct 25, 2007 | 03:00 PM
mr. maro's Avatar
Re: Please Help
cuz the ones on the back have the wider tires already on them. So if i can get away with a spacer it will be less work.
Old Oct 25, 2007 | 04:25 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Please Help
Sounds like you need to head out to the tire shop to have them all put on the right rims. Id do it right rather then try to force a solution. It might be more work now, but less aggravation later.
Old Oct 25, 2007 | 09:43 PM
BMmonteSS's Avatar
Car: 84' Monte
Re: Please Help
What Dimented said,
There is over 1/2" of backspacing difference between the wheels, no good way to use a spacer that thick and don't even think about washers.
