Vacuum based tables in L03 TBI bin
I'm using TunerPro RT to work on the tuning of a '91 L03 engine in a '91 Caprice. I've done a little logging and data tracing just to get a feel for the system and its all working pretty well now, thanks to some help from Mark Mangus to get the .ads file for the Caprice working right.
I'm trying to get an understanding of all the tables in the bin, and I was surprised that there are a couple of tables based on engine vacuum rather than MAP, for example the table:
TCC Locked Spark Correction Vs. RPM Vs. Vacuum
Vacuum is not a variable sent back in the logging, so I'm assuming I have to calculate it as:
Vacuum = 100 - MAP
Correct?
Anybody know why they had these tables based on Vacuum rather than just basing them directly on the MAP?
Thanks,
Paul T.
Vacuum = 100 - MAP
Correct?
Thanks,
Paul T.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Vacuum based tables in L03 TBI bin
Vacuum = 100 - MAP
Correct?
Thanks,
Paul T.
Vacuum = 100 - MAP
Correct?
Thanks,
Paul T.
I am going to take a stab at the fact that Vacuum is fairly constant, where MAP will vary some due to weather, altitude, etc.
Fast355, what you said makes sense, but on this ECM it doesn't have a baro sensor (I don't think so anyway, '91 Caprice with L03 and 16136965 ECM) so I guess it must estimate the vacuum using the MAP value.
If thats what they are doing it still seems like it would have been less of a hack for the tables just to directly use the MAP value instead of this "fabricated" vacuum amount.
Paul T.
Paul T.
Car: 1983 G20 Chevy
Transmission: 4L60
Paul T.
Paul T.
