Iac settings?
Old Nov 19, 2007 | 11:28 AM
90c350's Avatar
Iac settings?
Im just wondering if it is ok to reduce the IAC settings in the prom to reduce them at a certian RPM/Temp?? I currently have my tps voltage at about .85v and I think that it should be at about 1.17 or less. Now I know that is probably fine but my iac counts in the bin are set at 19 during warm temps. Can I reduce these setting and then turn the idle set screw up a little to get more air flowing through the throttle body?? THanks for any help!!
Old Nov 19, 2007 | 02:31 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Iac settings?
On the DIY_PROM board, Tuning Guide sticky, under the '7747 ECM, is an article about how the '7747 IAC operates. Along with some set up hints.
Running 5 - 10 IAC setps on a warm idle in park/neutral, no A/C, no backlight heater (etc...) as read from a scan tool is best.
RBob.
specialized
Jun 18, 2022 09:26 AM
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 21, 2015 12:39 PM
perZ
Aug 15, 2015 01:17 PM
