Crosswing Intake on a TBI
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Has anyone used a Crosswind intake (by Professional Products) on their TBI motor. I read somewhere before that the airgap causes some odd temperature differential, that causes startup problems...
Re: Crosswing Intake on a TBI
Im running the PRM-Airgap and in negtative temps it starts up just fine!! You may notice a bit of a hesitation for the first few minutes of driving but other than that it works great for me. I have tuned the chip to compensate for most of the problems associated with an unheated manifold. Can you burn your own chips/ecm?? If not you may need to get it tuned after the intake swap.
509 camaro fan
Sep 6, 2015 10:43 AM
