Which 305's came with 193 heads
Old Dec 3, 2007 | 03:36 PM
offsetfactor's Avatar
Car: 89 Camaro RS
Transmission: Turbo 350
My car has 193 heads and a turbo 350 trans, but there is too much mess on the block over the 5.0L or 5.7L stamp to read it, but it looks as if it says 5.0L
Every book at work (O'reilly Auto) says 193 heads came off the truck 350's but mortec.com just says 305/350 with no explanation
If i have a 5.0L are these heads a performance upgrade if I get a cam? Or did they seriously not come on any 305 engines and I probably have a 350? If chances are its a 350 ima tear down till i can get in and clean that block stamp
Old Dec 3, 2007 | 03:52 PM
Car: 89 Camaro RS
Re: Which 305's came with 193 heads
well the block casting said this ( i ripped out dist to find block casting) did these motors come with 193 heads?
10243880...350...95-00...2 or 4...Vortec truck, Gen.I crate motors and "ZZ4", roller cam, one piece rear seal
Old Dec 3, 2007 | 03:57 PM
AFAIK no 305s came with those heads. I could easily be wrong about that though, but I don't think so. 305s typically came with the 187 casting; same basic thing (swirlies), just downsized for 305s.
AFAIK none of that block ever came in a vehicle with those heads. I could be wrong about that too but I don't think so.
Sounds like you've got yerbasic mix-n-match "rebuilder's special". One thing is CERTAIN: neither the block nor the heads came with the car. It's probably just some stuff somebody slapped together and into the car.
Old Dec 3, 2007 | 04:14 PM
Car: 89 Camaro RS
yeah i was worried because the car had a/c smog and everything but i live in alabama and most cars dont have that... but i ripped the car apart as much as i had to, to get that block casting number, so now im glad i atleast have a 350, so i can atleast buy the right parts for the car!
Jake_92RS
Jan 28, 2020 10:37 PM
dutch930
Sep 11, 2015 06:58 AM
theurge
Aug 21, 2015 12:46 PM
anesthes
Aug 8, 2015 09:37 PM
