Fuel pressure gage
Old Dec 7, 2007 | 11:58 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Fuel pressure gage
On my 89 firebird, I am 99 % sure I have a bad fuel pump but would like to do a pressure test to be sure. Unfortantly I can't find a pressure gauge that will work with the TBI set up. I have one for TPI, but the 9-13 psi a TBI runs on would barely register on it, also it is a schrader valve type gage.
Anyways where is a good place to get the lower range gauge? I've checked Advanced and Sears. I am thinking of just buying an autometer dash gauge and hooking it up to do the test, but would rather buy the tool type gauge.
Old Dec 7, 2007 | 01:52 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Fuel pressure gauge
'857
TBI system as you may know does not have a a fuel pressure test port. There are couple of places were you can test fuel pressure without invoking the laws of other universe. One place is next to a Fuel Filter - by inserting a 3/8" by 3/8" by 1/8" T from Summit SUM-G1710 ($5.88) and Summit 0-30 PSI Fuel Pressure gauge SUM-800130 ($17.95) or non liquid filled VDO-153004 ($19.95) with some length of 3/8" SAE30R7 or better hose.
In my case (conversion) I moved Fuel pressure gauge into engine compartment and it is permanently mounted on the firewall next to power brake booster.
//RF
Old Dec 7, 2007 | 02:32 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Does anyone make a schrader valve fitting (test port) that you can add to the fuel line? That would be great. However for my purposes the above will work I think, I don't remember off hand but isn't the fuel line on the 89 on the filter screw in metal line and not clamped rubber hose?
Old Dec 7, 2007 | 03:43 PM
RFmaster's Avatar
Car: 75 Beast
'857
You are correct regarding your filter configuration - filter uses female inverted flare coupling while rigid fuel lines use inverted male. According to WIX master application catalog your bird uses 33481 fuel filter.
It has been a while since I looked at filter particulars, but in your case I would just buy a new filter and find a good auto parts store that carries plenty of plumbing. You can always get a inverted flare adaptor to 3/8" hose beaded adaptor (both male and female). I simply do not recall flare size that this filter uses.
There are several TBI specific FP testers available, for example ATD-5634 and others ($75)
//RF
Old Dec 7, 2007 | 04:13 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Re: Fuel pressure gage
Autozone has TBI specific pressure gauges. You just unscrew the softline under the hood and connect a T-type shrader fitting that comes with it then screw the fuel pressure gauge hose to it. After done cap the t-type shrader fitting and its always there for quik testing .... Doing it at the fuel filter is rediculous LOL. ... Bought my gauge there for 23 bucks.
Old Dec 7, 2007 | 07:10 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Do you happen to have the part number from the autozone gauge.
Thanks for the help here, I'm sure my car thinks I forgot about it since its been sitting for a couple of months, just haven't had the time to work on it. :-(
I see summit has the tester though.
http://store.summitracing.com/partde...5&autoview=sku
but the autozone sounds like its got a better price.
Old Dec 7, 2007 | 07:27 PM
Jproz1167's Avatar
Nope but it looks just like the TPI counterpart but reads 0-to like 22psi has about a 2 foot hose and that special inline adapter.
That summit gauge has the inline shrader valve fitting I'm talking about. Like I said just thread it into your softline and hard line on the drivers side under the hood and when done testing just put a cap back on the shrader valve.
Might have a extra TBI gauge if your interested.
Old Dec 7, 2007 | 07:40 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
http://www.autozone.com/R,NONAPP1884.../addToList.htm
Found the one on autozone, I guess they went up in price, oh well it says the local one should have it so i'll check it out tommorow.
Old Dec 7, 2007 | 07:50 PM
Jproz1167's Avatar
Yep thats the one I am talking about .... easy to use and idiot proof you wont regret buying it ... simple is a understatement on using it.
Old Dec 7, 2007 | 07:54 PM
Jproz1167's Avatar
If your stock pump ever takes a dive put a TPI pump in. I have a TPI pump in my TBI car and it does just fine
Old Dec 7, 2007 | 08:01 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
I'm a little torn on swapping the pump since I am setting aside money to put in an LS1, and will have to swap it out again at that point, but I don't wan't to let the car sit in the meantime.
Old Dec 7, 2007 | 08:05 PM
Jproz1167's Avatar
TPI pump will run TBI and I would think it could support a LSx engine as well.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
