Adjusting Idle
Old Jan 11, 2008 | 11:18 AM
robster66's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
Adjusting Idle
How do I adjust the idle on a TBI carb? It seems pretty high around 1.3k
Old Jan 11, 2008 | 01:51 PM
Ronny's Avatar
Re: Adjusting Idle
TBI or Carb. TBI is really not adjustable. RPM is set in chip aka .bin. Maybe a vac leak. Or slop at butterfly shaft allowing air to enter.
Old Jan 13, 2008 | 07:58 PM
Brandon2350's Avatar
Car: 1993 Z-71 pickup
Engine: Heavily modified 355 on TBI
Transmission: Had a 4L60e. Now a 700R4
Axle/Gears: Bone Stock
Re: Adjusting Idle
What is it specifically that your trying to do? Are you trying to raise or lower your idle and why. If you can give some specific details we may be able to help you better.
Brandon
Old Jan 14, 2008 | 11:33 PM
MarkAJ86's Avatar
Engine: 305tbi
Re: Adjusting Idle
Seeing as he said its high at 1300rpms i think he wants to lower it.
Old Jan 15, 2008 | 12:51 PM
Jason89RS's Avatar
Re: Adjusting Idle
Yes there is a way to adjust your RPM's on a TBI, but I would first look at if you have a vacuum leak, increased base timing or the IAC needs to be adjusted, cleaned or replaced which may be causing he high idle. To adjust the idle you'll need to find aluminum plug on the front of the TBI by the throttle linkage. Remove this plug. Behind that is a screw (most likely torx) that you can use to adjust you're idle speed. You'll want to use an external tach rather than the one that's in the car.
Old Jan 16, 2008 | 09:04 PM
Re: Adjusting Idle
If your setup was ok and you changed nothing but it started idleing up higher, you definately dont want to remove that aluminum plug and attempt to lower your idle. This is usually done by experienced tuners when you have changed the airflow charestics of the motor. Changing this will definately change a lot more than your idle.
Check the items from the member above that he mentioned before even thinking about popping the plug.
Old Jan 17, 2008 | 09:20 AM
Ronny's Avatar
Re: Adjusting Idle
Look at IAC pindle to determine if it is working or very dirty. Key on engine off it should move. Check your hoses to TBI for a vac leak.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
