1.6 Roller Tip rockers on LT-1 Cam
Old Jan 14, 2008 | 09:45 PM
Nefarious's Avatar
Car: 1991 Camaro RS convert
Engine: 5.0L TBI
Axle/Gears: 4th gen axle/4.11 gears
I've been researching this for quite a while, but I haven't been able to a find good thread on running 1.6 rockers with an LT-1 cam without modifying the heads. So I called up Comp Cams to see what they thought about running 1.6roller tip rockers 1418-16 and the 981-16 spring, and they said that I should be able to pull it off. I'm going to be doing new valve seals and while i'm at it I want to change my springs and rockers. I never changed my springs when I first did my cam swap so i'm doing it now. So now I would like to see what you guys think before I go and buy the stuff. I have a 95 LT-1 cam with the longer dowel pin which I believe has .447 and .459 lift. If I can't make the 1.6 rockers work I will buy they're 1.52 rockers. Thanks Will
Old Jan 14, 2008 | 09:52 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 1.6 Roller Tip rockers on LT-1 Cam
well the 1.6 rockers will bring that lift up to .477/.490. thats way to much on stock heads, as your retainer should bottom out on the guide boss at .480 lift.
You can try and measure the setup to see if you have the clearance, but you will be close.
OR you can get .050" offset locks, and .050" of shims to raise the valvespring assembly up .050" which will give you near .530" of lift clearance which will be perfect for that cam.
Then again, i dont see you gaining much more with 1.6 rockers over the 1.52s so its cheaper/wiser to stick with the 1.52's
Old Jan 14, 2008 | 10:03 PM
Nefarious's Avatar
Engine: 5.0L TBI
Excellent
Old Jan 15, 2008 | 03:56 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Wouldn't you also worry about the studs pulling out?
Old Jan 15, 2008 | 04:05 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
it is something to worry about, but if you keep spring pressure down, like stock style springs and that cam, it SHOULD hold the studs in just fine. But it would be beneficial to get screw in studs or pin the stock ones
Old Jan 17, 2008 | 01:32 PM
Nefarious's Avatar
Engine: 5.0L TBI
Would .060" off shims add too much spring pressure? I haven't seen any thing that I could combine to get .050" off shims, or at least not in the summit catalog.
Old Jan 17, 2008 | 02:24 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
depends on the spring rate. example is my afr springs that i will be shimming to increase pressure. Rated at 135lbs at the seat at installed height of 1.800". with shims of .060" that installed height is now 1.74". Spring rate for the spring is 360lbs per inch. SO with .060" in compression from the shims will raise seat pressure .060x360= 21.6 lbs or 156.6lbs which is about where i want the spring pressure to be for my cam
with stock style springs, seat pressures are around 100lbs. an extra .01" compression at installed height will not drastically raise seat pressure. your talking 2-5lbs of pressure, which will HELP a stock valvetrain setup if anything.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
angel2794
Sep 8, 2015 06:22 PM
z28guy134
Sep 1, 2015 11:50 PM
LT1Formula
Aug 20, 2015 09:36 PM
