cam for a TBI 305
Old Jan 21, 2008 | 08:26 PM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Axle/Gears: 3:42 open diff
cam for a TBI 305
Chevrolet SB 1987-95 Hydraulic Roller Cam RV/Torque
Part Number: CS1079R
Manufacturer: Speed Pro
Pro 3000 Series Speed Pro RV/Torque hydraulic roller camshaft for Chevrolet SB 305-350 1987-95.
Specs are as follows: Advertised duration int/exh 273/288
Duration @.050 int/exh 198/210
Intake valve lift .433
Exhaust valve lift .462
Lobe seperation 112 degrees
Operating range 1200-4500 RPM with a smooth idle
I have this cam in my 88 TA with shorty headers with no cat and smog pump. It seems to idle smooth with the timing set at 8deg btdc. However i can sometimes smell gas at idle and wondering if it could run better. I would appreciate some suggestions or if someone has used this cam recently.
Old Jan 21, 2008 | 08:45 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: cam for a TBI 305
That cam is about the same as a stock L-98 cam, and just a smigen smaller than a LT-1 cam.
Any cam other than stock REQUIRES retuning to take full advantage. In most cases it's required to just get out of the driveway. Any funky AFR issues at idle or otherwise can easily be tuned out.
If I were you I would learn to burn your own proms as mail order tunes are junk. Once you can tune I would look for something in the 214-218 range. Should make power to just shy of 6k and with the proper bolt ons (headers, exhaust, intake) get you into the 13's. Considering you run high 16's stock thats not too bad.
Old Jan 26, 2008 | 01:00 AM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
up date on how its running,
i would figure it would need a re tune also, its pretty bigger than stock
Old Jan 26, 2008 | 10:52 AM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
in fact i ran all summer with this cam at times it would idle smooth when cold until it warmed up then it would run a little choppy. I managed to link this to a vaccum port for the thermac on the tbi unit that I plugged when I upgraded to an open element. Thus it seemed to run smoother when I just left this vaccum port open to suck in a little more air. I tested all sensors with a sensor probe and found everything ok. At this point from expierience I figuired that I should maybee change the ignition module. Luckily I got one from a local boneyard for 10 bucks and it seemed to run much smoother. Lastly I ran winaldl and got nothing out of the ordinary(ie: no trouble codes, no rich or lean flags). Anyone ever have this kind of problem with a cam swap. I would appreciate some recommendations!!!!
Old Jan 26, 2008 | 02:04 PM
89RS_82Z's Avatar
sounds like its doing better, alot of people knock the send off chips, but www.tbichips.com has a real good guy..... can talk to him give him your mods, what you got your timing set at and you cam card, because tuning your own, well i dont know but it looks a little...........over whelming, i dont know why, hell i can rebuild a motor all day long, work on my PC (somewhat better than most not as good as some ) plus all i have is 2 desk top computers....have you thought of going with an accel or MSD ign mod??
you said you left a vac port open and it seems to run smoother?? thats really odd, because with a bigger cam you lose some vac to start with, thats just odd, i wouldnt expect that
you also said you can smell some gas, do you have a cat??, because if you dont that can be some of that smell, i got that somewhat, just reminds me of the smell of any car/truck with no cat
Old Mar 16, 2008 | 10:24 AM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
I also have an 88 trans am w/ a l03 305 engine. I want a cam that has a rough idle cause i plan on putting votec heads and intake on my car. any suggestions?
Old Mar 16, 2008 | 05:30 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
There's really no getting around tuning the car yourself if you want to get into some serious power gains. I just got my EBL flash last week and I'm just waiting for a new laptop battery and then the tuning shall begin. I plan on getting a zeitronix wideband to complete my package.
xkingcodex
Feb 12, 2020 07:43 PM
junkcltr
Aug 2, 2019 11:12 PM
beastin91rs
Oct 9, 2015 07:38 AM
Dwayne614
Sep 28, 2015 08:33 AM
