TPS question
Old Mar 9, 2008 | 07:19 PM
Brian21's Avatar
Car: 1991 Pontiac Firebird
Engine: 5.0L TBI
TPS question
Ok, I went searching on this site for my answer, but couldn't seem to find it. I noticed that some cars have the adjustable TPS and some have the non-adjustable one. My 91 Firebird has the non-adjustable TPS. So here's my question, if it's out of spec, do I just have to replace it with a new one? I can't adjust it?
Old Mar 9, 2008 | 10:22 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: TPS question
Brian
The later ECM's (like yours) have ability to deal with wider range of TPS values and the older slotted TPS sensor mounts are no longer required. What is your TPS voltage at idle and WOT? Generally speaking, according to FSM, at idle 0.2 to 0.95 Volts is acceptable and TPS voltage should increase at a steady, linear rate until WOT is achieved. At WOT 5.0 volts (give or take) should be the norm.
You can check your TPS voltages with DVM by probing pin C of the TPS connector (dark blue wire).
//RF
Old Mar 10, 2008 | 12:01 AM
Brian21's Avatar
Engine: 5.0L TBI
Re: TPS question
Voltage at idle is right at 0.54 volts and WOT is around 4.6 volts.. All seems to be right within spec. This rough idling and surging is really starting to bug me.. Only surges at idle too, doesn't do it when I'm giving it gas or maintaining a certain rpm above 1k-1.5k. I've been noticing a gas smell lately too while I've been working on the car. Thinking I should probably check the fuel pressure regulator next.
Old May 13, 2008 | 05:48 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
Re: TPS question
did you ever find your problem
Old May 14, 2008 | 12:45 AM
Brian21's Avatar
Engine: 5.0L TBI
Re: TPS question
Well, I found my problem with the surging.. That just took replacing my TPS and IAC valve and adjusting it.
Unfortunately I haven't figured out my rough idle problem yet. My car actually idles a little smoother in drive than it does in park. Still trying to figure out why that is.
I'm getting ready to put a new exhaust on and smog my car, so we'll see if this rough idle is actually a slight miss or what. I'm thinking if the car is missing, I should fail my emissions test pretty horribly.. We'll see though..
I guess I should add that other than the roughness, the car runs great. Doesn't smoke or burn any oil, has lots of power (for a 305). Also just recently drove it on a 200 mile trip and it did great. That's why I don't really think it's anything too serious. Just more of an annoyance than anything else.
Old May 16, 2008 | 12:40 PM
Ronny's Avatar
Re: TPS question
My non adjustable TPS when new was .55 at 0% and 4.5v at 100%.
mdtoren
Aug 23, 2015 12:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
