NEED HELP!! QUESTIONS ABOUT MY ENGINE!
Old Mar 16, 2008 | 10:07 AM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
I have a 1988 Trans Am w/ a 305 TBI. It's all stock and i ned to know is my camshaft a hydralic roller or a flat tappered?
Old Mar 16, 2008 | 10:35 AM
Rob 97 Z28's Avatar
Engine: D17A2, L31 based sbc, LS1, LM7
Transmission: 5 spd, built 700r4, T-56, 4L60e
Axle/Gears: 4.11, 3.73, 3.42, 4.56
Re: NEED HELP!! QUESTIONS ABOUT MY ENGINE!
As far as I know, ALL F-cars 87+ were all hydr. roller
86+ they went toa 1 piece rear main
Old Mar 16, 2008 | 10:57 AM
Engine: Vortec 357
Ok thanks cause i recently bought an Edelbrock Performer Plus camshaft but come to find out its a flat tappet. So in order to use it i have to swap pushrods. But im putting a set of 96+ Vortec heads and intake manifold on so im going to buy the 08-500-8 Comp Camshaft and return my Edelbrock. Is that comp cam a good choice or can i use an LT4 or LT1 cam?
Old Mar 16, 2008 | 11:46 AM
Rob 97 Z28's Avatar
Honestlydude, you should keep it hydr. roller.
seriously, because
A) thats what it came with from the factory
B) theres no break in for a roller cam
C) it may effect the rest of your valvetrain
D) It may effect performance.
Also cam bearings. How are your's? What did you cam journals look like when you pulled it out? If they have any kind of scoring or appear as though theres been a starvation of oil at any point on them at any time you will want to replace them.
Alot of guys use the LT1/LT4 cam's in the EFI 305's that came in the F-cars i know. However the cam is only going to take you so far. The factory heads that came on L03's really kinda suck for any performance/power building
Old Mar 16, 2008 | 12:05 PM
Engine: Vortec 357
the cam journals looked fine no wear. I am going to keep it roller but i didnt relize that the cam i bought was a flat tappet which is why im bringing it back to get the comp cam. and im replacing my heads and intake with thos eof a 96+ 305 Votec heads and intake from a 1996 chevy Z71 4x4 truck. Just have to send the heads out to be remaned and order new springs.
Old Mar 16, 2008 | 12:19 PM
Rob 97 Z28's Avatar
Good stuff meng!
I've always heard the vortec heads were really good heads from the factory so for your application maybe some mild porting, new valve stem seals, guides and a slight mil job to bump up the compression a lttle, slap her back together and start saving for a converter and
Old Mar 16, 2008 | 12:22 PM
Engine: Vortec 357
yeah seeing as i already ran a high 15 stock, this setup along with the cam, my headers, timing kit, and shift kit and maybe even a 454 TB should get me well into the 13's lol
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
