Best mods for 305 TBI
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Ok so far ive installed on my 305 TBI w/ 9,000 miles i have:
3" Hooker Super Competition Longtube Headers w/ full 3" exhaust
Flowmaster 80 Series
Accel Super Stock Yellow 8mm Wires and U-Groove Platnium plugs
Accel High Perf. Distributor Cap and Rotor
Edelbrock Chrome Air Cover w/ K&N 4" round filter
Transpack Shift Kit for my TH 700R4
Catyalatic Converter Delete
I plan on doing a B&K Under drive Pulley 3 peice kit, Hypertech Theromaster Chip w/ 160 degree thermostat, possibly a new Edelbrock TBI intake manifold. My question is, what other upgrades would you reccomend i do to get the most hp out of my engine before i start to do "internal" upgrades? Im on a tight budget and have been looking for the best yet inexspensive upgrades. Any suggestions? I do plan on putting a Magnaflow High Flow 3" Cat back on the car but will i lose hp doing that or will my engine perform better putting on back on. I can notice alot of black soot buildup on my rear bumper after i was it then drive for a few miles so thats the biggest reason on putting one back on especially after the car gets painted in a few weeks. But is there any more inexspensive or free mods i can do my engine to give it a lil more umph or "get go"? I also plan on a A/C delete and Smog pump pulley delete later this spring. Any imput is apprecitated!
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Best mods for 305 TBI
I have a friend that just installed them a few weeks ago, we suppose hp went up somewere between 0.1 - 1.5 hp because dosent make any difference.
0 hp gains + bad miles per gallon
0 hp gains
Loocks like you can save some $ and time.
Engine: Vortec 357
Im guessing with what i have installed right now im at least around 200-205 hp. The car comes stock at 170. But the smog pump and ac delete are going to happen anyway because neither work so it will just save me time to take them off now and it will save me some weight. I was told that the chip will help because yes you are only running at 160, but the computer will read the sensors as the engine is still cold so it will dump more fuel which will produce more hp and yes it will get crappy gas milage, but the car is only going to be a street/strip car so it wont get driven everyday like it is now.
1 Post
Car: 91 Trans am
Lowering thermostat ° without fan switch sensor ° doesent make sense.
A good tune, 180° thermostat, 200-210° on/off fan switch and cold air intake is what tbi likes in hot conditions. Basicly a rather hot engine with fresh air.
Yust for your own science (doesent have to be expensive and good loocking), feed plenty of fresh air to your engine when its healty hot and then do the 160° hipertek mod for comparison.
Engine: Vortec 357
Im still looking for a cam that i can run that will still work with my stock ecm. I was told an Edelbrock Rolling Thunder would work. But i was also looking at a Comp Cam Xtreme Energy Camshaft and my dad told me i could run that cam with my stock heads as long as i ran new springs, but i wouldnt be gettin the optimum performance out of my cam unless i tuned it with a flashed ecm. is this true?
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
save the money on the hypercrap chip, and buy your own hardware to burn you own chips. its been proven that the hypertech chip basically adds timing, and not much else. i think it works out to about the same amount of money.
Engine: Vortec 357
sounds good. any recommendations about a cam?
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
I think we are able to put 305 (Lb9) heads on our LO3's. Maybe someone can add to this and clear it up some but I believe that there are gains to be seen in doing that.
Engine: LO3
Axle/Gears: 3.08
For a cam, many will suggest a LT1 cam, when it's time for me ill go a little warmer then a LT1 and get something that will give me a little chop in the idle ) Not at that point yet so there is nothing really I can add to a cam choice.
Engine: Vortec 357
And can i run an LT1 cam in my car without having to replace my ecm or re tune it?
Car: 91 rs
Engine: tbi 350
Transmission: 700r/manual
No dont try that. Hypertech is a waste of $, dont go with the edlebrock tbi manifold, go with the carb manifold and an adapter, I say this because the tbi manifolds bores are 43mm, your stock tbi is about 46mm, somewhat of a restriction to be honest, and you wont notice a difference. Dont waste money on the underdrive bull, go buy a 50'' belt, get rid of the smog and a/c if you can or want to, you will notice a difference. That mod alone dropped my old lo3 0-60mph from 8.49 to 8.24. If you want to go with a 160 thermo it is a good idea but you WILL need a chip. Cooler engine=longer lasting and better breathing. The fan switch is helps alot, especially in traffic.LB9s are a solid 10hp.
Engine: Vortec 357
sounds good. What kind of chip would you reccomend running if i was to get a 160 thermo. Ill look into getting a carb manifold w/ an adapter. I just purchused a throttle body spacer off ebay for bout 35 bucks.
You can use the Edelbrock TBI manifold and it make a differance, just get the holes bored out to 50mm. yes it works, ask me how I know. As far as underdrive pullies they do work as well but if your willing to spend the money get the WHOLE kit not just the pullies. It will free up ALOT of room on the front of your engine plus remove a good bit of weight as well.
1 Post
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
It has been widely debated weather the TPI heads are better than the TBI, and I doubt LB9s are an automatic 10hp without port work and/or a tune to go with it. I think Fast355 has proven that the L30 059 heads are a premium choice for a hot 305. I have some 416 heads (LB9/L69) heads that I was going to use for my 305, but now I am thinking 059 heads.
Car: sold
I have a chip from my old TBI computer I got off Ebay a while back cant remember what it cost me but it help me out alot, I ran a 15.20 with everything you have minus the headers, and I have 373's and I did the ultimate TBI mod on this site I will sell it to you for 15 shipped if you want to try it, and of corse that was befor the lt1 and t56
1 Post
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
yes L69 heads do give more power. higher compression They do work well for TBI. Lets be honest though all that $ could go towards an LTx and you would hit 300hp pretty easy and still get ~20 mpg. I have a 305 too but refuse to mod b/c of the 350 option.
Engine: Vortec 357
i only plan on doing small monds just to gimme what i can out of the 305 for now until it takes a **** on me. Then i have a 383 stroker pushing almost 500hp all motor in the garage waiting to go in something. I also would like to put the T5 in my car that sitting in my totaled formula. But ill just do what i can for now till later down the line i can afford something bigger like the engine swap.
I have 2 edelbrock carberated manifolds in the garage. 1 came on the 383 when we got it and its a Tourqer? Is that any good of just plain crap? Then we also have another one but im not sure what model. id have to take a look so i can already save myself money there and dont have to buy another manifold.
Last edited by TADailyDriver; 04-06-2008 at 12:29 AM. Reason: Automerged Doublepost
Engine: Vortec 357
haha must be nice. rite about now i can only go 210 miles on a full tank.... it sucks ***....gunna run some sea foam and clean up the injectors and replace the fuel filter today. sounds good to me man...
Car: 1983 G20 Chevy
Transmission: 4L60
LTx is a pain in the rear. The 305 could EASILY make 300 HP from the stock shortblock. ZZ4 heads, a nice cam upgrade, single plane intake, and EBL controlling things.
Engine: Vortec 357
L69 heads will give you the SAME EXACT compression ratio of the current engine. They also have a poorly designed combustion chamber that will not make the same power your current TBI heads will.
