Lasting Tbi Problem
Old Apr 12, 2008 | 08:36 PM
lovemymaro's Avatar
Car: 1991 Camaro Rs
Engine: 305 TBI
Transmission: 700-r4 with no OD :(
Lasting Tbi Problem
Ive had this problem with the tbi since i got the car. When you get it to a certain RPM it starts to buck..It gets worse when the car is warm or you drive it and turn it off, and then crank it back up. It idles fine and drives fine before that RPM.
So far ive done:
plugs, wires, cap, rotor
all sensors in the car
checked all fuses
Fuel delivery looks good(nice misty cone)
Oil Changed, filter
Coolant Flushed
i think the emissions stuff is unhooked
ive had past codes 25 34 and 54..but ever since i tuned it up they havent came back
only thing i havent done is fuel filter...but i dont see how itd be the problem..any suggestions plzzzzzzzz
Old Apr 12, 2008 | 09:09 PM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Re: Lasting Tbi Problem
Have you pulled the codes from the ECM yet?
Old Apr 12, 2008 | 09:21 PM
lovemymaro's Avatar
Car: 1991 Camaro Rs
Engine: 305 TBI
thats the crazy thing about it..it doesnt show a code..i had a code for my map sensor earlier and one for my IAT but both of those were cleared.
Old Apr 13, 2008 | 01:45 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Ignition module tested?
Old Apr 13, 2008 | 05:52 PM
lovemymaro's Avatar
Car: 1991 Camaro Rs
Engine: 305 TBI
Woo--i was thinkin that no one was going to reply
but no ive never tested the ignition module...guess thatll be the next thing to get. Just curious, how does a bad ignition module, cause this problem?
Old Apr 14, 2008 | 04:07 PM
Car: 91 Camaro RS
The module gets warm and it stops sending the signal to the coil to fire. If you end up replacing the module, I would recommend the coil as well. The two seem to fail about the same time.
Old Apr 14, 2008 | 09:35 PM
lovemymaro's Avatar
Car: 1991 Camaro Rs
Engine: 305 TBI
okay apprecitate it..always happy to learn something new..im really hopin this works im trying to sell the car but i need it to be in top running condition cuz i dont wanna cheat anyone.
Old Apr 30, 2008 | 02:34 PM
lovemymaro's Avatar
Car: 1991 Camaro Rs
Engine: 305 TBI
okay well it seems that the Ignition Module and the Coil were not the culprits. The car runs a little better but it still persists to struggle at a certain throttle point. Its especially noticable when accelerating off of a hill like place..any more suggestions..??
Old May 3, 2008 | 02:48 PM
lovemymaro's Avatar
Car: 1991 Camaro Rs
Engine: 305 TBI
Anyone!?!??
92camaroJoe
Jul 29, 2023 07:57 PM
dyeager535
Aug 28, 2015 08:10 AM
zeitghaist
Aug 18, 2015 07:33 AM
92camaroJoe
Aug 13, 2015 06:07 AM
