Urgent Help needed !
Old Apr 26, 2008 | 04:49 PM
greywuuf's Avatar
Car: '89 RS
Engine: 305 TBI (painfully stock)
Axle/Gears: 3.08
Where do you guys get injectors ?
I have a bone stock 89 RS (305 TBI) that wont pass an emission test and I have a bit of a miss ( thus the high idle and 2500 rpm HC readings ) anyway on looking down the throat it is clear my injectors are not spraying a decent pattern. I donthave time to send em out to be cleaned so i thought I would just replace em .....
Heart attack time Dealer quoted 483.00 EACH ( keep in mind I paid 500 bucks for the whole care ) and the parts houses in town are getting anywhere from 189 to 289 each for them ( and of course they dont have em in stock )
where do i go to be sure of getting good quality injectors and how much should I expect to pay for them ?
is there any tricks to maybe a garage possible cleaning ?
Old Apr 26, 2008 | 07:46 PM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
Re: Urgent Help needed !
try a used set from someone on the forums or ebay or try junkyards
Old Apr 26, 2008 | 09:02 PM
DM91RS's Avatar
Car: 91 RS
I've been using this with good results. I don't know how it will work on a very dirty unit though. You might have to take the injectors apart and change the screens if they are beyond cleaning and soak the injectors in the solution.
http://store.summitracing.com/partde...5&autoview=sku
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
