What air system should i go with?
Old May 17, 2008 | 05:21 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
This is what i got now.
I'v been told to get rid of it and throw it away.
so what do you guys think that will be good for my engine?
thanks
kevin
Attached Thumbnails What air system should i go with?-mvc-001f.jpg   What air system should i go with?-mvc-002f.jpg
Old May 17, 2008 | 11:35 PM
RicksIroc86's Avatar
Car: 84 camaro z28
Re: What air system should i go with?
whats wrong with it?
Old May 18, 2008 | 07:31 AM
I'v been told they catch on fire with alot of them.
this is what i am looking at.
Old May 18, 2008 | 08:27 AM
JohnyP's Avatar
Car: 92 Camaro RS
Engine: 383
Transmission: t-56
Axle/Gears: 4.11
i'm sure whoever told you that is a guru and can make a car faster by looking at it since you know the open air element hasn't been used since man threw a big motor in it and called it a race car....yeah definitely worthless because there still making them and so many people are still using them.......if you cant hence my sarcasm im just gonna stop.....throw a k&n high flow in there and MAYBE go to a 360 round one 3-4in depending on your hood no drop base (defeats the air flow purpose) btw i use one on mine.....\
can you send me an 8x10 autographed glossy of the car god that told you "it catches on fire" lol
Old May 18, 2008 | 10:11 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If the engine backfires out the intake the foam element does burn/melt. This is a common problem with carb setups. EFI rarely backfires (on occasion they do).
If your engine/tune is OK and there isn't any backfiring then try it out.
RBob.
Old May 18, 2008 | 04:09 PM
So like the cold air intakes arent really worth buying?
kevin
Old May 18, 2008 | 07:03 PM
Car: 84 camaro z28
haha send me one too please
Old May 18, 2008 | 08:50 PM
DM91RS's Avatar
Car: 91 RS
It may seem funny but if you do get a backfire it will melt as much as burn. You want that on top of what is going into the engine. I had one on my first car [63 Impala] It did exactly what I mentioned. Not good and had to be replaced. Like Rbob said it is more of a problem on carbed applications that are prone to backfire.
On the other hand if they had a k&n type material that is fire proof it seems to breath very well and on the last parts car I purchased it was the only filter that the previous owner found that would fit with the hi rise intake some DA installed.
Old May 18, 2008 | 09:51 PM
Can you guys show me something that looks cool and does the job good?
kevin
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
overdriv
Aug 20, 2015 03:52 PM
bryan623
Aug 10, 2015 11:33 AM
