Code 15
Old May 28, 2008 | 10:35 PM
Artic White's Avatar
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Code 15
So every so often while I'm driving my SES light would light up for 10 maybe 15 seconds and go away. Today i decided to try and pull the codes and what i got was 15.
My question is would the coolant temp sensor have any effect on gas mileage?
Old May 29, 2008 | 07:29 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Code 15
Yes, very much so.
Also check the connector to the CTS. They tend to corrode which causes false readings from the sensor.
RBob.
Old May 29, 2008 | 09:32 AM
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Re: Code 15
This may sound like a dumb question but where is the sensor located?
Old May 29, 2008 | 11:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Code 15
Top front of the intake manifold. To the passenger side (US) of the thermostat housing. Has a 2-wire weatherpack connector. Probably yellow & black wires.
RBob.
Old May 30, 2008 | 07:56 PM
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Re: Code 15
RBob.
Thank you so much. I looked again right after I answered the question and I found it
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
