Holley Projection TBI and Intake
Old Jun 1, 2008 | 08:20 AM
69442DREAMCAR's Avatar
I replaced my tired 305 in my 89 RS with a GM goodwrench 350 truck crate engine. Only upgrades were a Comp Cams 260H cam. I also bought a Holley 670 Projection TBI and a Holley Projection alum. intake. It runs really well but has a bad stumble when you stomp unless you load the converter with the brakes first. Will the swap of the Holley unit help or hurt this if I swap before I get the chip correct. I know this is TBI section but would I be better off to swap to a carb with this set up? Any suggestions will be greatly appreciated.
Old Jun 1, 2008 | 08:33 AM
DM91RS's Avatar
Car: 91 RS
Re: Holley Projection TBI and Intake
Sounds like you need more AE added in the chip for when you stomp it. Need to tune.........and yes if you add the Holley it will need even more
Frozer!!!
Jan 19, 2024 04:55 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
