IS my TPS adjustable?
Old Jun 5, 2008 | 10:02 AM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
I seem to be seeing a lot of mention that my stock 92 RS will NOT have an adjustable TPS, is that true for 100% of them or do they have different types?
Old Jun 6, 2008 | 10:15 AM
Car: 92 Camaro RS
Axle/Gears: Stock
Re: IS my TPS adjustable?
Where is Vader when I need him!? LOL
Old Jun 6, 2008 | 03:11 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The stock one isn't adjustable, it doesn't need to be. As long as the TPS volts at idle is between .45 and .95 volts it is good to go (I think that actual range is greater then that).
RBob.
Old Jun 6, 2008 | 05:38 PM
Car: 92 Camaro RS
Axle/Gears: Stock
Thanks man - I am checkin my IAC this w/e andf I read that u have to adjust the TPS after adjusting the IAC, but I guess the non-adjustable ones have a wide enough range it doesn't matter then.
Old Jun 6, 2008 | 10:09 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
For a TBI setup the best IAC adjustment is to get it between 5 and 10 steps. This is at idle with no other loads (A/C, backlight heater, in park, etc.).
If you are reading about the '7165 MAF ECM for the early TPI setups. It doesn't apply to your ECM.
RBob.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
FormulaEngland
Sep 30, 2015 01:50 PM
