AFPR range
Old Jun 21, 2008 | 08:35 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
AFPR range
What is the typical range of a TBI afpr?
I modified the stock fuel pressure regulator to make it adjustable and I'm not getting much of a change in pressure. Originally, I had ~11 psi. After modifying the regulator and all but maxing it out (judging by the tab seen in the housing opening) I'm only getting ~11.5 psi.
Does the regulator spring have to be changed to something stiffer to see any larger changes in pressure? BTW - The TBI was just rebuilt, incl the regulator diaphram.
Old Jun 24, 2008 | 10:28 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Re: AFPR range
I see 10-20 psi advertised for some aftermarket AFPR's. Can anyone verify this is possible w/ the stock spring by simply making the stock regulator adjustable?
Old Jun 25, 2008 | 04:54 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: AFPR range
In addiction to the AFPR I got a stiffer then stock FP spring from xtremefi that cant even hold 18psi under accelleration.
Ill have the 20psi spring from Top down solution installed soon.
I never tried but doubt you can get over 13psi under load with the stock FP spring. (apperently stock tbi Fuel pump doesent pump more then 14psi either)
Definally set the adequate fuel changes in the bin for the higher FP.
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
